Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Corvette ZR1
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette ZR1
General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Sponsored by
Bill Stasek
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-10-2009, 02:59 PM   #1
Katech_Jason
Premium Supporting Vendor
Katech_Jason's Avatar
Send a message via AIM to Katech_Jason
Default LS9 head stud kits now in stock
We now have LS9 head stud kits which are a direct replacement for the OEM head bolt. Includes studs, nuts, washers and required lube. $299.99
http://store.katechengines.com/Product203
__________________
_Jason Harding
Director of Aftermarket Operations, Katech Performance
__________________________________
http://www.katechperformance.com
YOUTUBE
FACEBOOK
MAILING LIST
Katech_Jason is offline   Reply With Quote
Old 11-10-2009, 07:32 PM   #2
OnPoint
CF Senior Member
Support Corvetteforum!
OnPoint's Avatar
Location: Wichita Kansas - 2011 Callaway GS 606HP & 2010 ZR1 638HP
Jason,
Pardon my ignorance, but are these to rectify a weakness with the stock motor, or are these something someone who is bumping up the power/boost of a ZR1 might consider?
Travis.
OnPoint is offline   Reply With Quote
Old 11-10-2009, 09:26 PM   #3
Katech_Jason
Quote:
Originally Posted by OnPoint View Post
Jason,
Travis.
There are a number of reasons why you might use head studs.
First, all fasteners stretch when they are torqued. This is what provides the clamp load. Fasteners return to their original length when they are removed, unless they are stretched to a point where they can not return. This is called the yield point. Some fasteners, such as head bolts, are TTY (Torque To Yield) and are not reusable. Head studs such as these have a torque spec which is below the yield point of the fastener so they can be reused. Reusing head studs can make it more cost effective than using bolts in applications where changes to specification or components, or repairs/rebuilds necessitate removal of the heads.
Second, head studs can provide more uniform clamp load on the head gasket because they have not been torqued to their yield point and they are often made from stronger materials, have been heat treated and have a higher tensile strength. This is effective for extreme duty racing applications or boosted applications such as the LS9.
Third, and the most important right now, LS9 head bolts are unobtainable at this time.
__________________
_Jason Harding
YOUTUBE
FACEBOOK
MAILING LIST
Old 11-11-2009, 04:08 PM   #4
Katech_Jason
Well, good news on these kits. The response has been pretty good and the volume may be higher than I originally thought. So, we have been able to increase our volume and reduce the cost per piece. We have reduced the retail price to $299.99/set which is the same price as our other head stud kits.
__________________
_Jason Harding
YOUTUBE
FACEBOOK
MAILING LIST
Reload this Page LS9 head stud kits now in stock
Tags
bolt, bolts, gasket, gaskets, head, headbolts, heads, kits, ls9, nitrous, reusable, stock, studs, torque, zr1
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
