Anyone have the remote fuel filler door release button malfunction?
I have like 2200 miles on my 09 ZR1 went to the fuel station and the remote release would not open the filler door. I had to use the manual override release in the trunk area. I guess I will take it in to the dealer tomorrow.
Also I have noticed a brake squeal when I apply the brakes, anyone else have either of these two issues?
I believe the break squeal is a normal condition.Remember your driving a race car with full blown racing brakes. Just curious did you do the brake burnishing after break in ?
My fuel door does that sometimes. I just tap the button a few times and it will open. If it is intermittent, it is probably the actuator. If not, it could be the actuator, fuse, or wiring. It will be covered under warranty.
__________________
_Jason Harding
Director of Aftermarket Operations, Katech Performance
Jason,
I'd like your professional thoughts on the brake burnishing mentioned in the above posts?
