Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Corvette ZR1
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
C6 Corvette ZR1 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-22-2009, 12:54 AM   #1
ZR1Gerhardt
CF Senior Member
2010 Chevrolet Corvette
Default ZR1 Brake Burnishing
I am about out of my first 500 miles. Do I need to do the brake burnishing procedure (i.e. accelerate up to 60, brake hard, do 50 times , etc.)? The manual has the procedure listed in a different section and seems to indicate that is necessary if the car will be used on the track. But if that is necessary to maximize brake performance, would that then be necessary for daily driving also? Just curious.
Thanks in advance for any advice.
Scott
ZR1Gerhardt is offline   Reply With Quote
Old 10-22-2009, 01:10 PM   #2
MarkP
CF Senior Member
MarkP's Avatar
Scott
Scott,
I think this is what you're looking for:
http://www.corvetteactioncenter.com/...nish+Procedure
MarkP is offline   Reply With Quote
Old 10-23-2009, 03:44 AM   #3
Torched
CF Senior Member
Torched's Avatar
Send a message via AIM to Torched
Quote:
Originally Posted by MarkP View Post
Scott,
Thanks for posting very helpful
Torched is offline   Reply With Quote
Old 10-25-2009, 07:37 AM   #4
ZR1-Germany
Junior Member
Default 5 times 0 - 300km/h - 0 also ok?
For my stomach it will be better to change this procedure to:
5 x 0-300-0(km/h) app. 5 x 300m = 1500 brake path instead of
50 x 0-100-0(km/h) app. 50 x 30m = 1500 brake path.
Any tech. reason why this may not have the same result ?
ZR1-Germany is offline   Reply With Quote
Old 10-25-2009, 11:49 AM   #5
dvandentop
CF Senior Member
dvandentop's Avatar
wow very good info i wonder how many owners actually will do that
dvandentop is offline   Reply With Quote
Old 10-26-2009, 12:13 AM   #6
ZR1Gerhardt
CF Senior Member
I am not sure how many people actually do this. But if you read the manual closely, it says you should do this two purposes: (1) track, and/or (2) high performance street driving (i.e. you play with the go pedal, you may want to make sure the stop pedal works at its peak). So I would say that unless it is just a show car or you never plan on getting on it, you should do this procedure. I could be wrong.
If it would ever stop raining here in IL, I might actually get to 500 miles, change the oil, and then due the brake burnishing. But if it does not stop raining, I am going to have to build an arc for the car.
Scott
Old 10-26-2009, 12:16 AM   #7
howl
CF Member
The weather here in IL has been great - if you are a duck.
howl is offline   Reply With Quote
Old 10-26-2009, 12:24 AM   #8
ZR1Gerhardt
CF Senior Member
Quote:
Absolutely right. Even my Chocolate Lab does not want to go outside and she likes water.
Scott
Old 11-02-2009, 04:35 AM   #9
ZR1-Germany
Junior Member
Default I did it my way
The german way of brake burnishing
http://videos.streetfire.net/video/Z...300_716175.htm
Scott
Old 11-02-2009, 09:00 PM   #10
Cringle
Junior Member
Scott,
Thanks.
Cringle is offline   Reply With Quote
Reload this Page ZR1 Brake Burnishing
Tags
brake, brakes, braking, branishing, burnishing, corvette, dose, gm, kind, procedure, time, video, zr1
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
