[ZR1] New Record Times for Stock ZR1
#41
Good job guys !!!!
It would be very pleasant to live near of you... I could go to race with some very very good driver and passionated Corvette Z06 and ZR1 guys !!! But damn ... The little Canadian is too far ....
Congrats again,
Later,
Sébastien
Congrats again,
Later,
Sébastien
#42
That is so cool! The ZR1 is a beast and those are some impressive times. Congrats guys.
You guys should consider coming out to this rental in nov:
http://forums.corvetteforum.com/perf...rnie-king.html
#44
Great job Neil and Ranger. I received the e-mail invite and thought about driving down from Annapolis but was tied up at work. BTW- I heard you coming out of your neighborhood followed quickly by your Dad.
#45
You guys are my heroes!!
#46
Ranger did you scan the ZR1 during the runs? Anything interesting noted therein, such as timing pulled during shifts, or heavy IAT spark effects or anything else?
What was the launch RPM/shifting technique? Cool down technique?
Any nuances to the dual clutch in launching or shifting? Any pedal issues like we all suffer?
Racerrn that is some accomplishment to get 1.7's on stock tires! Fast shifting is only a bit of practice away... though your shifts sounded very fast...did you scan and compare the shift time to Rangers?
I'll stop now. I always have 20 questions.
#48
Unsurprising results for an incredible car and incredible drivers I knew you guys could make it happen. CONGRATULATIONS! You make the Corvette community extremely proud indeed and I am eager to see more.
#49
I doubt that many ZR1s will ever see the track. In light of that, Z06Jeff, racerns and I set out last April to demonstrate the capabilities of the car in straight-line max acceleration. This is a stock car with warranty in tact. In so doing owners without the opportunity or inclination will still see it documented and know their cars are the new king. That was shown clearly on this car's second track day. And two more this season are planned.
Ranger
#50
Congrats guys! It amazes me what a difference drivers make, one day I hope to be bangin' gears with the best of 'em
#51
#52
A great way to safely R&R wheels with carbon rotors is to use one of those gadgets that lifts the tire on rollers and lets you roll the car around on casters. Jack the car, then support the tire with the gadget to remove and install.
You can run any of the 18" drag radials.
I've mounted CCW Corsair Race wheels (only come in 18") on the ZR1 and the fit is tight but sufficient to clear the 15" rotors. I've not tested wheel alternatives to the Corsairs, since I already had a pair of them for my Z06.
If you order Corsairs, be sure to tell John or Chip at CCW that the wheels are for the rear of a ZR1. That will ensure correct offset/back-spacing.
When changing tires, take care to mount the blue booties over the C/C rotors, to avoid an expensive, hard lesson-learned.
In an abundance of caution, we have been using two pairs of hands to maneuver the wheel on and off the hub.
Ranger
Ranger
#53
Now, if I could just fit that thing into my Z06, with the cargo bay and passenger seat already pretty much cubed out with track gear. Might fit something more, so long as it's sand.
Been considering a trailer. But seems a luxury for a DD.
Ranger
#54
That said, I've made just 6 passes in a ZR1 on drag radials. So the 60' is a work-in-progress. Sequence in Monday's three passes was
1.72
1.71
1.68
1320' were
10.730
10.734
10.736
Ranger
#57
#59
You need one of these. < $200 from Harbor Freight and stores upright in garage taking up very little space. Only problem is, the regular c6 hitch didn't fit the Z06 due to the Z's muffler vacuum tanks...they may have changed the design by now, I've had mine since 2006 and haven't looked lately.
Ranger
#60
Ranger
