Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Corvette ZR1
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
C6 Corvette ZR1 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-13-2009, 12:58 PM   #41
gm4life
CF Senior Member
gm4life's Avatar
Quote:
Originally Posted by Deuuuce View Post
Hey guys, first post. New here but I reference the Fast Lists often in various threads. Been around for a few years, check out my signature, thanks!
OP, what about GM's statement about cooling issues for the ZR1 if the boost is increased?
Thanks!
Well, when my signature finally shows, it is this:
'06 Charger SRT-8 413rwhp/432rwtq
CAI, cats/catback, manifold spacer, Diablo dyno tuned
12.71 @ 111mph
'02 FXSTDI Softail Deuce
Apes and Factory purple
Transportation Examiner and car blogger:
www.cartruthblog.blogspot.com
and
http://www.examiner.com/x-5826-San-Jose-Autos-Examiner
Your here too? Damn how many GM forums you on?
gm4life is offline   Reply With Quote
Old 06-09-2009, 08:22 PM   #42
WeaponsGradeTorque
CF Senior Member
Quote:
Originally Posted by INTMD8 View Post
A naturally aspirated car will almost always have higher trap speed vs a similarly powered forced induction car for a few reasons.
One is weight, a couple hundred pounds adds up.
Second is intake air temperature. The naturally aspirated car will have near ambient intake air temperature through the traps, making the same actual power it did on the dyno at that point in time. Same goes for nitrous though IAT's will be well below ambient.
Not sure what the IAT's were on this ZR1 but it could be well upwards of 150deg through the traps meaning it's actual power on the big end is a bit less than what it achieves on the dyno.
It may have only reached IAT's of 20-30 deg above ambient on a dyno pull.
Only way to closer equalize the two would be to run the naturally aspirated car on a 150deg day or increase the efficiency of the intercooler system on the FI car to achieve ambient IAT's through the traps. Meth injection could drop down the temps as well.
This guy knows what he is talking about.
WeaponsGradeTorque is offline   Reply With Quote
Old 06-09-2009, 09:00 PM   #43
Andrew M
CF Senior Member
Andrew M's Avatar
Send a message via AIM to Andrew M
Quote:
I would say neither of you has a clue.
Even if peak numbers are the same the FI car will have a much broader torque and power band than an NA car.
Andrew M is offline   Reply With Quote
Old 06-09-2009, 09:21 PM   #44
GForceSS
CF Senior Member
GForceSS's Avatar
If the forced induction car has an inefficient cooling setup, then sure it will drop trap speed at the end of the ¼. However, most experienced FI owners have efficient setups and are closer to ambient than you might think. For example, my twin-turbo car on an 80 degree day logged 91 degrees IAT at the end of the ¼, that icludes heating the tires up before the run.
GForceSS is offline   Reply With Quote
Old 06-14-2009, 02:43 PM   #45
WeaponsGradeTorque
CF Senior Member
This is funny.
Old 06-14-2009, 02:44 PM   #46
WeaponsGradeTorque
CF Senior Member
Quote:
That is excellent. I like the turbo's better than the SC's, that is for sure.
Old 06-15-2009, 11:44 PM   #47
Flash99
CF Senior Member
Support Corvetteforum!
Flash99's Avatar
Get back out to the track, LFE got you at 10.03, I guess they have the worlds fastest ZR1 now.
http://forums.corvetteforum.com/c6-c...41-50-mph.html
Flash99 is offline   Reply With Quote
Old 06-16-2009, 01:05 AM   #48
Ranger
CF Senior Member
Ranger's Avatar
Has a time slip ever been posted for the 10.05 pass by the ZR1 owned by nc1205? If yes, please post a link to it.
Ranger
__________________
'06 Z06 red 236 passes
Bone Stock Stock Tires……11.10 127.76 1.79 60'
Bone Stock DRs......….…….10.74 129.50 1.59 60'
'02 Z06 350 passes
Bone Stock Stock Tires……11.81 117.26 1.78 60'
w/ CAI & DRs………...........11.52 120.21 1.64 60'
My PR Details
Improve Your Shifting General Launch Techniques
Maintain Your Clutch Burnout without a Line Lock
Ranger is offline   Reply With Quote
Old 06-16-2009, 01:12 AM   #49
Warren262
CF Senior Member
I don't get it, this car claims 730whp and traps 138mph. The lingenfelter claims 739whp and traps 142mph on a warm day. Lingenfelter must have better cooling system I guess.
Warren262 is offline   Reply With Quote
Old 06-16-2009, 01:53 PM   #50
redknight
CF Senior Member
Quote:
I'm pretty sure its hot in miami too plus the driver of that car supposedly weighs around 350 lbs. In addition, that car is running the much heavier stock wheels in the front compared to the lingenfelter car's ccw drag pack. Times and trap speed make sense to me given similar power but other differences.
The lingenfelter package does seem like a much more efficient and safe way to make the power though.
redknight is offline   Reply With Quote
Old 06-16-2009, 02:19 PM   #51
bgreen83
CF Senior Member
bgreen83's Avatar
Send a message via AIM to bgreen83 Send a message via Yahoo to bgreen83
Quote:
Ranger
I think he had a video posted. I'll check
This is of the 10.21 run. don't think there is one for the 10.05 run
http://videos.streetfire.net/video/W...ZR1_639596.htm
bgreen83 is offline   Reply With Quote
Old 06-16-2009, 02:28 PM   #52
dlo3575
Junior Member
dlo3575's Avatar
Ditto, very nice numbers. I can't bring myself to run mine on the track.......
dlo3575 is offline   Reply With Quote
Old 06-16-2009, 06:53 PM   #53
GForceSS
CF Senior Member
GForceSS's Avatar
I love Turbos too. It takes thought to get a really efficient cooling system going. After using high power shop fans to create usable air deflectors into the intercoolers and measuring air relief flow behind the intercooler, the setup was able to actually produce better than ambient temps cruising. At 60mph on 90 degree day I have dozens of logs showing 80-82 degree IATs. With the same creative thinking, the ZR1’s setup can be enhanced a great deal in terms of cooling; sounds like Lingenfelter had done much of this already.
Old 06-17-2009, 07:41 PM   #54
CFHay
CF Senior Member
So... you blew the motor in this?
CFHay is offline   Reply With Quote
Old 06-17-2009, 08:18 PM   #55
Ranger
CF Senior Member
Ranger's Avatar
Thanks for the link to the 10.21.
Surprised there's only a skinny post asserting 10.05, but no slip, no video, no details. Anyone here witness the pass?
Ranger
Old 06-18-2009, 08:02 AM   #56
thee Dragon
CF Senior Member
Ranger
It's irrelevant at this point.
His motor is blown to crap.
Blown as in destroyed.
__________________
Christopher's TSP Fully-built Aluminum 402 LS2 '01 Trans Am Bilstein FIREHAWK M6 (Built by GM EXPRESS RACING) Recaro Sport Topline Leather & Suede Seats.
thee Dragon is offline   Reply With Quote
Old 06-18-2009, 10:12 AM   #57
SGCZR1
CF Senior Member
What happened to it?
SGCZR1 is offline   Reply With Quote
Old 06-18-2009, 01:33 PM   #58
redknight
CF Senior Member
That's to bad. Can't say I'm suprised though. Seemed like he just haphazardly threw mods at it. He nearly doubled the boost and the only intercooler upgrade was a bag of ice sitting on top of the supercharger.
Old 06-18-2009, 02:45 PM   #59
PRAY
CF Senior Member
Quote:
If you can't, I will for you. I am local and I think my numbers speak for my driving skill.
If you own a welding shop on 210 then we have met in the past.
__________________
02' Black Z06. Bone stock 12.16@116.31. Old NA 383 numbers 490/445rw 10.87@129.76. New N/A 416 573/530rw 10.21@136.12.
PRAY is offline   Reply With Quote
Old 06-18-2009, 02:53 PM   #60
canamvette75
CF Senior Member
canamvette75's Avatar
Quote:
some details would be nice
canamvette75 is offline   Reply With Quote
Reload this Page WORD'S FASTEST ZR1 back to the track.
Tags
atco, zr1
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
