Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Corvette ZR1
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette ZR1
General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Sponsored by
Bill Stasek
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Closed Thread
Old 03-14-2009, 12:47 AM   #1
turbo24
CF Senior Member
Support Corvetteforum!
Default Splitter clearence
ZR1 owners>
Is the splitter length and ground clearance a very big issue?
turbo24 is offline
Old 03-14-2009, 01:13 AM   #2
1 BAD ZR1
Full size member
1 BAD ZR1's Avatar
Not for me. And I lowered mine too.
1 BAD ZR1 is offline
Old 03-14-2009, 09:08 PM   #3
blue devil 1
CF Senior Member
Default How low can you go
There is actually more clearence (vertically) on the ZR1 splitter than there is on the ZO6. Of course, the ZO6 is a plastic material (more durable and less expensive) therefore more forgiving.
blue devil 1 is offline
Old 03-14-2009, 10:15 PM   #4
Blow N By
CF Senior Member
Blow N By's Avatar
No scrapes yet. Caught the Z06 a couple of times.
Blow N By is offline
Old 03-14-2009, 10:58 PM   #5
ZO6Jeff
CF Senior Member
ZO6Jeff's Avatar
No problems as of yet. I just take it real slow over speed bumps and am extra careful when pulling into a parking space with a concrete barrier or curb.
__________________
Jeff
2009 ZR1
1990 ZR-1
ZO6Jeff is offline
Old 03-15-2009, 01:53 PM   #6
Gene Culley
Platinum Supporting Vendor
Gene Culley's Avatar
I'm sure you'll find both stories listed here... both it is ok for them and both it is not ok. Lots of people have been hitting them on the curb parking at the convenience store, etc. It is all in how careful you are like others mentioned.
__________________
Founder of GM Parts House
Home Of The Corvette Parts And GM Parts Specialist
Please Visit GM Parts House Online or Call 484.949.2099.
Gene Culley is offline
Old 03-17-2009, 11:42 PM   #7
turbo24
CF Senior Member
bump
turbo24 is offline
Old 03-21-2009, 03:32 PM   #8
Red Rochester
CF Senior Member
Red Rochester's Avatar
ttt
Red Rochester is offline
Old 05-27-2009, 02:45 PM   #9
2from53
CF Senior Member
I have a Z06 and it is impossible to back out of the driveway without
scrapping the splitter. Will a ZR1 be the same or worse ? Is it possible to
replace the splitter on a ZR1 with a Z06 splitter ?
2from53 is offline
Old 05-27-2009, 03:22 PM   #10
MTIRC6Z
CF Senior Member
The angle of attack can make a difference...if I back straight out my driveway a stock Z06 splitter will scrape (car is lowered) but when I take it at an angle no scraping.
When I come across something like a big speed bump, I will be sure to take it at an angle, the sharper the better, getting one tire going up well before the other can make a big difference.
Hitting a parking curb is just plain careless, no reason for it to happen.
Cheers, Paul.
MTIRC6Z is offline
Old 05-27-2009, 03:42 PM   #11
Splitter
CF Senior Member
Splitter's Avatar
Splitter is offline
Old 05-27-2009, 04:13 PM   #12
IndyPacer
CF Senior Member
IndyPacer's Avatar
No issues with mine scraping. I can actually get out of the drivway without scraping like the 07 & 08's do!
IndyPacer is offline
Old 05-27-2009, 04:26 PM   #13
Jofu
CF Senior Member
Jofu's Avatar
Are you truly scrapping the front Z06 splitter, or are you simply scrapping the rubber/plastic thingy hanging right ahead of the front wheels (the parts you can only see when kneeling down)? If it's the former then wow, that's quite a steep driveway you got there!!!
Personally, the only time I scrappe my front Z06 splitter is when taking a very tight and steep downhill corner). It sure doesn't sound good when it happens!!!
Geoff
Jofu is offline
Old 05-27-2009, 05:08 PM   #14
2from53
CF Senior Member
Geoff
Yes, it is the forward-most splitter. That is why I would want to replace the CF piece on a ZR1 with a plastic Z06 splitter. I plan to buy
a ZR1 in the future, and was wanting to know whether I could change the ZR1 splitter with the Z06 version.
2from53 is offline
Old 05-27-2009, 11:25 PM   #15
09C6ZR1
CF Senior Member
09C6ZR1's Avatar
Send a message via Yahoo to 09C6ZR1
Ehhhhhhh......I've had a few problems...Some from my own stupidity but I look at it another way......I'm just sharpening the undersisde of the splitter so it'll cut the air better........
Keep a few in stock for me Gene
09C6ZR1 is offline
Old 10-22-2011, 05:54 AM   #16
Richard Roys
CF Member
Default How do I raise front of car and should I?
Glad that this is a topic, Had the C6 "plastic thing that is in three parts" and it had scrapes and so did the bottom of the bumper. Now I have had a OEM wide body Zo6 kit installed with OEM plastic splitter. So I do take care when going out of my drive way because if I don't it does scrape. Even when I drive my Limo it will bottom out if not careful. So I get the angle of taking each bump in the road. But just yesterday I noticed it scraping "from the sound" when driving on a road that had a few bumps & potholes. I put 19' front and 20' rear rims on could this be a factor of my car being lower? I did see on a post that someone had raised the front of their car how was that done and not sounding cheep but a ball park figure would be appreciated.
I will buy an extra splitter so I have on hand because at this rate I will need a stock pile of them. Funny enough I had taken sand paper the first time I had scraped it just was what came 2 mind. I enjoy driving my car and really don't want the feeling like it is a special sunday driver. Would be nice if it had the option on my S600 that will raise almost four inches when needed btw was a 9 grand option.
Richard Roys is offline
Old 10-22-2011, 11:02 AM   #17
Tact
Law Dawg Moderator
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
Tact's Avatar
http://forums.corvetteforum.com/foru...s-or-more.html
Tact is offline
Reload this Page Splitter clearence
Closed Thread
Tags
c6, scraping, splitter, zr1
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
