Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Corvette ZR1
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette ZR1
General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Sponsored by
Bill Stasek
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-09-2009, 06:54 PM   #1
apsisusa
Platinum Supporting Vendor
St. Jude Donor '07
Default POLL: ZR1 Customers Do you want the Front Splash Guard?
Hi ZR1 Folks,
The Z06 customers are suffering severe paint damage around the rear brake duct area because there is no Splash Guard protection on the front wheel. We have made the Front Splash Guard for Z06 and the Z06 customers are very happy about it. Now they have peace of mind. They give us very high marks for this great product.
For ZR1, we guess you will have same or even worse paint damage problem because the ZR1 runs so fast.
So we are considering to make the Front Splash Guard for ZR1. We will offer either the standard Black Raw Parts or in Black Carbon.
Will you be interested in such Front Splash Guard for your ZR1? Please let us know your opinion.
Since we don't have pictures for ZR1 Splash Guard to show you, so we post some Z06 pictures for your reference so you can get some idea.
Here are the pictures------------
apsisusa is offline   Reply With Quote
Old 03-09-2009, 07:39 PM   #2
Pumba
CF Senior Member
Support Corvetteforum!
Pumba's Avatar
Am I correct in assuming that you have done some WIND TUNNEL testing of your splash guard to ensure that it does not disturb the negative pressure air flow that makes the front brake cooling ducts work? Or is this a cosmetic-only piece?
The deflectors in front of the wheels were designed by Corvette engineers to create that negative pressure.
__________________
Fidanza Dual-Disc Clutch - Liberty ZR1 Trans w/2.66-1.78-1.30-1.00-0.79-0.628 gears - RPM ZR1 3.42:1 Quaife Diff - L.G.M.: Trans&Diff
Coolers-Headers-Coilovers-CFiber D'Shaft - Pfadt Pfatty Bars - Mamo LS7 T'Body - TPiS LS6 intake - DRM Brake Ducts - ZR1 Carbon-Ceramic Brakes
Corsa Pro-Series Indy - SETRAB Oil Cooler - RD Radiator - DeWitts Fans - MCM Hood - Cafaro Spoiler - Tiger Shark Fascia - Carbon-Fiber Splitter
Pumba is offline   Reply With Quote
Old 03-09-2009, 08:05 PM   #3
1 BAD ZR1
Full size member
1 BAD ZR1's Avatar
I would not want them. That's what Clear Shield is for.
1 BAD ZR1 is offline   Reply With Quote
Old 03-09-2009, 09:14 PM   #4
CORVETTEZL1001
CF Senior Member
CORVETTEZL1001's Avatar
No.
CORVETTEZL1001 is offline   Reply With Quote
Old 03-09-2009, 10:01 PM   #5
tome
CF Senior Member
tome's Avatar
No!
tome is offline   Reply With Quote
Old 03-10-2009, 12:48 AM   #6
638HP
CF Senior Member
yes, as long as brake cooling is not an issue as posted upstream.
638HP is offline   Reply With Quote
Old 03-10-2009, 01:43 AM   #7
breakskeet
CF Senior Member
breakskeet's Avatar
No, thank you.
breakskeet is offline   Reply With Quote
Old 03-10-2009, 11:06 AM   #8
MTIRC6Z
CF Senior Member
I would think the side skirts on the ZR1 would provide the same benefit (stop stone chipping) as these splash guards while at the same time being aerodynamically beneficial? Am I correct in this thinking? I have a Z06 and would much sooner pay the extra cost of the side skirts under the assumption that I get both benefits.
So do ZR1s get the paint blasted off the side of their car the same way Z06s do?
Cheers, Paul.
MTIRC6Z is offline   Reply With Quote
Old 03-10-2009, 12:12 PM   #9
apsisusa
St. Jude Donor '07
Hi Guys,
Thanks for your opinion. Since most opinions are negative so we will pull the plug.
Some Z06 customers report that even they have the clear protective film but they still got some paint damage. Maybe ZR1 have the Side Skirt and it will reduce the potential paint damage. We will see.
Anyway, in the future if you guys feel there is a need for the Splash Guard please let us know and we can make it available.
Jersey
Old 03-10-2009, 05:54 PM   #10
Xwet
CF Senior Member
I think for some one who uses their Z06 for non-track, the splach schields are no issue.
Xwet is offline   Reply With Quote
Old 03-11-2009, 01:08 AM   #11
carczar
CF Member
Send a message via MSN to carczar Send a message via Skype™ to carczar
Use a clear bra, and there is no problem, easy install
carczar is offline   Reply With Quote
Old 03-11-2009, 08:58 AM   #12
MTIRC6Z
CF Senior Member
Default My question still stands...
Has anyone put enough miles on their ZR1 to be able to judge whether the side skirts are effective at reducing 'paint blast'?
Cheers, Paul.
Old 03-11-2009, 11:55 AM   #13
blue devil 1
CF Senior Member
Default Blasted
Number 43 here. I've got about 6000 miles on mine and am not showing any signs of paint chipping or wear in that area. I did put the clear bra on the nose and agree, its the only way to go. Ryan @ Auto Paint Guard in Tampa is the best.
blue devil 1 is offline   Reply With Quote
Old 03-11-2009, 01:36 PM   #14
FAST ZR1
CF Senior Member
FAST ZR1's Avatar
no thank you! Clear Bra thank you.
FAST ZR1 is offline   Reply With Quote
Old 03-11-2009, 06:57 PM   #15
JamRWS6
CF Senior Member
Thank god we won't see any ZR1s with those hideous looking...mudflaps...on them.
JamRWS6 is offline   Reply With Quote
Old 03-27-2009, 07:08 PM   #16
cal333
Junior Member
Default ZR-1 Splash Guards
I purchased a set of the Z06 guards and modified them to fit the front fenders of my ZR1 - basically, you have to cut off a lot of the lower part of these guards to make them fit around the lower graphite running board - you have to run some extra screws into the far inside to hold them sturdy - I agree on the clunky looks of these guards but the Michelin Pilot tires pick up gravel and rocks like machine guns and sling it all back on the sides and rear air ducts - there is no way to adequately protect everything with clear shield, even the side of the fenders and doors - I don't like the fiberglass construction of these guards, it would be better done in hard rubber - they do fit well if you take some time - I put a line of black tape under the edge of the guard that contacts the fender to prevent scuffing the factory paint - its too bad that GM does not produce these guards, but these are better than chipped paint
cal333 is offline   Reply With Quote
Old 03-27-2009, 11:14 PM   #17
apsisusa
St. Jude Donor '07
Quote:
OK, now we got the first report from ZR1 customer about the paint damage. I guess once ZR1 customers drive more mileage you will probably feel the same need. Let's wait and see.
Can you post some pictures so we can get the idea how it looks?
Reload this Page POLL: ZR1 Customers Do you want the Front Splash Guard?
Tags
bra, brakes, c5, clear, corvette, disc, fenders, front, guard, guards, lower, splash, street, zo6, zr1
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
