[ZR1] Eaton TVS R2300 compressor map
Premium Supporting Vendor
Behold...
I could not find this so our friends at Magnuson hooked us up. I was curious to see if the speculation that the LS9's supercharger was out of it's efficiency range at 18psi. By our calculations, this is not the case. At 7000rpm, the supercharger loses 6% efficiency going from 10.5psi to 18psi. In my opinion, 6% is not a huge drop.
The debate came up due to a ZR1 that made 700rwhp and these numbers seemed low. I think another contributing factor is that on the chassis dyno, these cars must be seeing tremendous heat soak in the intercoolers. I would be curious to see what the intake charge temperatures are in these conditions.
Speaking of intercooling, the delta temperature going from 13,000rpm (10.5psi relative pressure) to 16,000rpm (18psi relative pressure) takes you from 90 degrees F, to 220 degrees F. If you're adding 130 degrees to the intake charge without increasing intercooling capacity there is your power loss.
Supporting Vendor
Location: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
Received 1,425 Likes
St. Jude Donor '08
Behold...
Full size member
You are very correct about the heat soak. We would lose 50hp after heat soak on my ZR1.
Jason, can you repost that picture with a line drawn over it to represent the stock operating conditions and a line to represent the modified operating conditions? This will make it much more obvious to those not used to reading compressor maps.
IMO, the ZR1 heads are likely a restriction. They have a huge swirl producing feature in the intake port that will surely improve emissions through better fuel mixture but will almost surely kill their power production potential as well. Stick a good CNC program through that intake port and I bet that 18 psi of manifold pressure will drop pretty quick.
Likewise with the stock motor at 10.5 psi, I was a little shocked to see "only" 638 hp out of a motor of this size with that much positive manifold pressure...
Has anyone flow-benched the stock ZR1 heads yet? Since the cam in the car in question was changed it leaves only the heads as suspect IMO.
What style of intake port was used on the ZR1 head? Will other GM heads swap in?
10.5 psi = 1.7 PR
18 psi = 2.2 PR
If you follow the immaginary 13,000 RPM line up to an intersection with the immaginary 1.7 PR line you get about 65% efficiency, and if you follow the 16,000 RPM line up to the immaginary 2.2 PR line you get about 61% efficiency. This tells me the drop is more like 4%.
Did I do this wrong?
Here is the an estimation. I made sure to not that on the image before this gets quoted all over the internet.
Unfortunately the pressure map does not go over a 2.4 pressure ratio so the 18psi dot is off the scale. For those who will ask why 18psi is not 2.2 pressure ratio like it should be, we estimated a pressure drop over the intercoolers since Eaton is measuring the compressor discharge pressure and the car is measuring manifold pressure after the intercoolers (I think).
I think LS9 head ports are the same as LS3. I'll go check.
One more thing, how are you seeing a 6% drop? I did the following:
10.5 psi = 1.7 PR
18 psi = 2.2 PR
10.5 psi = 1.7 PR
18 psi = 2.2 PR
I think my most recent post answers this. In short, we estimated a greater pressure drop over the intercoolers at a higher boost level. When you do it this way you get 65%-59%=6%. These are just estimations. We don't know the actual.
So the ZR1 will need a larger heat exchanger if the boost is turned up?
Hmm... it would be interesting to flow a set of LS9 heads to see what GM's interpretation really means in practice. A stock LS6 with headers will make similar peak power with only ~7 psi from a centrifugal. Better intercooling might make up part of the centrifugal's advantage, but I'd be suprised if it was all in the intercooling since the LS6 has smaller intake ports and is a smaller motor by a half liter.
they flow 314 cfm and they will flow more. but they are not the reason for higher iat's when running more boost.
1 Post
check out this link for more info http://www.enginelogics.com/cmaps.html
St. Jude Donor '08
so, you are saying the weak link is the intercoolers?
that could be a possiblity.. i also think the car might make more power on real driving experience as you are getting fresh air...
the only thing the kind of makes me think it might not be the cooling is b.c the guy who made 700.. let the car cool off with a bag of ice and it still did not help...now i do not know how long or how cold the engine got.. but it should have had one 800rwhp pull.. from dead start?
I would hate to use the word weak link. How about "completely engineered upgrade package." If you're adding more power you need to get more heat out right?
I personally think the bag of ice does nothing. It might draw some heat away from the top of the intercooler housing, but seriously, how much heat could you really be drawing from the entire system?
1 Post
I definitely agree with you.
Very good political stance too
