C6 Corvette ZR1 & Z06General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
didnt seem to hurt it too much. we did several back to back runs and only lost about 2-3 mph on the second run. we had 2 runs with worse et's but with trap speeds of 137.5 and 137.8 mph!
I think this car got some 10.5-10.7s with better lunch and faster shifting, trap speed is already there.
Put some DR in that beast & let's see some 10s runs
My vette went 9's with that mph! I'm guessing there's more et in it.
Given the largest DRs available are 18" I'd like to see how you'd get a 15" brake rotor inside that size wheel...probably ain't gunna happen.
Cheers, Paul.
Cheers, Paul.
The 18" will not fit over the rear rotors/calipers on a ZR1, but a 19" will. And Hoosier makes a nice sticky tire for the 19", however, it is still a stiff wall tire which is not good for drag racing.
