Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Corvette ZR1
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C6 Corvette ZR1
General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Sponsored by
Bill Stasek
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-18-2008, 09:00 PM   #1
Hgreen0814
CF Member
Hgreen0814's Avatar
Default ZR1 Performance
Has GM announced what they think the performance stats will be for this car? 0-60 1/4 mile etc?
Hgreen0814 is offline   Reply With Quote
Old 02-18-2008, 09:18 PM   #2
curvesman
CF Senior Member
curvesman's Avatar
Not yet! I am guessing 11.2 1/4 mile
curvesman is offline   Reply With Quote
Old 02-19-2008, 09:51 AM   #3
flight23
Junior Member
Quote:
Didn't Ranger already do that in the Z06? I would guess a ~10.8 at a massive trap speed.
flight23 is offline   Reply With Quote
Old 02-19-2008, 03:04 PM   #4
02MillenniumVette
CF Senior Member
02MillenniumVette's Avatar
Quote:
Ranger did a 10.85 in the 1/4 with just slicks on his Z06. But not everyone is as good as him either.
I think 11.2 is probably a good number to go by but we will see.
02MillenniumVette is offline   Reply With Quote
Old 02-19-2008, 04:43 PM   #5
32valves
CF Senior Member
maybe GM should publish the best customer 1/4 ETs they can find on the internet for all thier vehicles.
I think GM says 11.7 @ 125 for the Z06
32valves is offline   Reply With Quote
Old 02-19-2008, 06:34 PM   #6
flight23
Junior Member
So GM's published numbers are 5/10ths slower than what the car is actually capable of? What is the point of that? Shouldn't the published numbers indicate the peak capability, rather than just an average time? Not being contentious here, but that seems kind of silly.
I think I saw Ranger's 11.2 on street tires...
Old 02-19-2008, 06:38 PM   #7
JamRWS6
CF Senior Member
So when 99% of owners can't achieve the factory spec you think they are going to be happy?
JamRWS6 is offline   Reply With Quote
Old 02-21-2008, 05:51 PM   #8
TTC5Z
CF Senior Member
stock Zo6 on street tires has recently run sub 11 times.
10.9_ @ 129 trap
So ... ZR1 should be good for 10.5 @ 138 +
TTC5Z is offline   Reply With Quote
Old 02-21-2008, 06:03 PM   #9
masssrt
CF Member
Quote:
10.9_ @ 129 trap
Saleen S7TT numbers
masssrt is offline   Reply With Quote
Old 02-21-2008, 06:07 PM   #10
BLU-BY-U
CF Senior Member
BLU-BY-U's Avatar
I don't believe GM takes the same approach as the drag racing crew - they don't show up with 1/4 tank gas, change air pressure, cool the car for 1 hour, wait for a negative density altitude day, etc. I'm not even sure GM tests on a real drag strip or uses NHRA process of having two trap timers and averaging the last 60 feet (1260 feet to 1320 feet) to arrive at trap speeds. So in the end, I think the 11.7 factory spec is about right ET wise (real hard core guys will go lower as we have seen on a well prepped surface) and the 125 trap is probably a bit inflated (assuming they don't average 60 feet like the drag strips do). I'd imagine they take the trap of 125 right at the 1320 mark and thats going to be slightly inflated versus a real nhra run.
don't confuse factory specs with nhra 1/4 racing
BLU-BY-U is offline   Reply With Quote
Old 02-21-2008, 06:37 PM   #11
vrybad
CF Senior Member
vrybad's Avatar
10.9_ @ 129 trap
My guess is that the ZR1 dynos around 570rwhp if 620fw, so what should a stick car with 570rwhp trap?
I'm guessing mid 130's on average.
vrybad is offline   Reply With Quote
Old 02-21-2008, 06:49 PM   #12
dontbescaredofme
CF Member
10.9_ @ 129 trap
No way 10.5 on stock tires on 20" rims. 138mph seems a little high as well. Low 11's and maybe high 10's.
dontbescaredofme is offline   Reply With Quote
Old 02-21-2008, 06:57 PM   #13
robvuk
CF Senior Member
robvuk's Avatar
Send a message via AIM to robvuk Send a message via Yahoo to robvuk
Quote:
High 10's, meaning 10.9, trap around 130. 138 is a bit optimistic. If this car traps at 138, that indicates low, low 10's.
robvuk is offline   Reply With Quote
Old 02-21-2008, 09:32 PM   #14
jamie furman
CF Senior Member
jamie furman's Avatar
Quote:
If the car weighs in 200 lbs more than the Z06 the HP to WGT isn't going to be that big a difference, about like adding 50 rwhp to the Z. I would guess a decent driver low 11's around 130 would be my guess? But there is more to it than that, as the extra weight might not allow the car to leave as good as the Z or the extra torque combined with the extra weight might make traction near impossible? Or maybe it will be a 10 sec rocket ship! I think that we will just have to wait and see when they come out.
jamie furman is offline   Reply With Quote
Old 02-21-2008, 10:42 PM   #15
benspruce
CF Senior Member
benspruce's Avatar
Quote:
When conducting performance tests do they account for the weight of the driver? One driver might weigh 200 lbs, another could weigh 150 lbs, hence a difference of 50 lbs for the car to deal with. Pardon my ignorance on such matters, but it seems it could make a small difference in test results.
benspruce is offline   Reply With Quote
Old 02-21-2008, 11:04 PM   #16
misteroman$$$
CF Senior Member
misteroman$$$'s Avatar
Quote:
Tell them they need to learn how to drive better
Derek
misteroman$$$ is offline   Reply With Quote
Old 02-22-2008, 02:53 AM   #17
Slow Vette
CF Senior Member
Slow Vette's Avatar
this ZR1 should see 130+ mph trap speeds in the low low 11's
Slow Vette is offline   Reply With Quote
Old 02-22-2008, 06:15 AM   #18
vtecnitian
CF Senior Member
vtecnitian's Avatar
is the zr1 going to have a stock roll bar if not everyone getting kicked out on their first pass lol.
vtecnitian is offline   Reply With Quote
Old 02-22-2008, 01:08 PM   #19
tome
CF Senior Member
tome's Avatar
It looks like there won't be any way to run the ZR1 at it's full potential at the dragstrip based on current sanctioning body rules. 11.49 and quicker requires roll bars! I guess you might get one full pass, then you'd be gone. NHRA is going to be VERY aware of what these cars will do, so they will be watching very closely I'm sure.
I know a guy who made a PVC roll bar for his C5 convetible with metal covering so magnet would stick and he never got questioned. Car ran just under 12.50 @ 112; However, 11 flat at 130 is a much bigger hit if something happens, so that's a real bad idea.
tome is offline   Reply With Quote
Old 02-22-2008, 01:45 PM   #20
TTC5Z
CF Senior Member
If the car weighs in 200 lbs more than the Z06 the HP to WGT isn't going to be that big a difference, about like adding 50 rwhp to the Z. .
I'd say more like 80 RWHP advantage. Also the power under the curve is more consistent.
GM has built us a high 10 sec. car ... and the best drivers will lower that by another 4 tenths.
Reload this Page ZR1 Performance
Tags
corvette, o100, zr1
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Lingenfelter 475 93 ZR1 for Sale Rkreigh C4 ZR-1 Discussion 97 12-02-2004 09:13 PM
C6/Z06 performance comparison... 08msmZ06 C6 Corvette General Discussion 84 06-18-2004 08:05 PM
SGC TT ZR1 - BOOSTAMUV!! Rkreigh C4 ZR-1 Discussion 168 04-05-2004 01:50 AM
Lingenfelter 1993 ZR1 Rkreigh C4s for Sale/Wanted 82 02-12-2004 07:21 PM
C5 2003 faster than ZR1 ? Mylzi C4 ZR-1 Discussion 21 11-13-2003 11:06 PM
1990 DRM 450 ZR1 for sale Rkreigh C4s for Sale/Wanted 130 01-09-2003 07:22 PM
Z06 performance compared to New Viper C4ForGeeGee C5 Z06 Discussion 116 12-09-2002 04:10 PM
UPDATE ON 95 LPE ZR1 TWIN TURBO NO. 3 OF 4 NORM KOERNER C4 ZR-1 Discussion 144 01-09-2002 05:12 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
