C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
Help! What are these lines connected to the C6 Z06 dry sump
Old 03-22-2024, 10:37 PM
1wet.vette
1wet.vette's Avatar
Default Help! What are these lines connected to the C6 Z06 dry sump
Hello. Attached is a photo of two hard plastic lines that are connected to the dry sump. one line is circled red and one is circled blue. Will somebody please tell me what these are called. The one circled in red is broken on my car and comes off very easily and I want to replace it but don’t know what it’s called?
Old 03-23-2024, 02:39 AM
ws6outlaw
ws6outlaw's Avatar
Take a look at this. https://www.corvetteforum.com/forums...on-an-ls7.html
Old 03-23-2024, 12:02 PM
Hib Halverson
Pro Mechanic
Pro Mechanic
Hib Halverson's Avatar
Received 1,150 Likes on 602 Posts
GM calls those PCV pipes. OE replacements are going to be hard to find.
Old 03-23-2024, 02:32 PM
Spaceme1117
Spaceme1117's Avatar
Received 1,321 Likes on 892 Posts
The hard pipe and connectors can be replaces with rubber fuel hose. The proper type of connectors can be purchased from Mighty Mouse.
The following 2 users liked this post by Spaceme1117:
Bertram65 (03-27-2024), Glenn Bland (03-25-2024)
Old 03-25-2024, 07:18 PM
KennyPowers
KennyPowers's Avatar
Callout 3 part no above.. might be some floating around.. call your GM dealer.. GL
Old 03-26-2024, 10:06 AM
David@MMS
Supporting Vendor
David@MMS's Avatar
we have many of these here
https://www.mightymousesolutions.com...quick-connects
Old 03-26-2024, 05:25 PM
1wet.vette
1wet.vette's Avatar
Originally Posted by David@MMS
what size are the fittings? There are a couple options for certain things and I don’t really know what size fitting I need etc?
Old 03-26-2024, 05:28 PM
David@MMS
Supporting Vendor
David@MMS's Avatar
The medium.
__________________
Solutions for the common gearhead #made in USA
facebok.com/mightymousesolutions
#mmsolutions
Six time NMCA True Street Champions
Home of the first Twin Turbo C7Z 7.81 @ 176
3470# Stock bottom end and heads Corvette Stock Bottom End Record Holder
Old 03-26-2024, 06:01 PM
KennyPowers
Hate to give away, since itll be a grab for parts in coming years, but check
car-part.com
Grand Valley Auto Parts MI
Auto Works Inc corvettes WI
1wet.vette (04-05-2024)
Old 03-27-2024, 10:42 AM
KENS80V
KENS80V's Avatar
If it's the tubing that is broken/cracked then dual wall adhesive lined shrink tubing can be used to make a repair.
To Help! What are these lines connected to the C6 Z06 dry sump
Quick Reply: Help! What are these lines connected to the C6 Z06 dry sump
