Z06 positive battery lead broken
Hi, did this happened to anyone? And how should I go about replacing it? Doesn't looks like there is a lot of slack to install an aftermarket one. Thank you
erikszr1 (03-01-2024)
Moderator, Tech Contributor
Received 2,135 Likes
You can pick up these gold plated battery terminals at Autozone and cut off the old connection and reinstall the new…I’d do both and be done with those crappy OEM connectors !!
The following 3 users liked this post by C5 Diag:
Adrien Marsoni (03-01-2024)
