[Z06] Spring Pressure
Spring Pressure
Can’t really find an answer to this question:
Are .660” dual springs okay for an OEM LS7 cam with OEM LS7 lifters?
Is this too much pressure on the lifters or am I not thinking about this correctly?
Thanks!
Thanks!
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,106 Likes
My only question is.. Why?
OEM springs control the valve train with an OEM cam just fine. No need to go with stiffer springs. You'll actually suffer a tad more parasitic HP loss for no reason too.
Thanks for your reply. My 2009 ZO6 had a lifter fail that wiped the camshaft so I’m in the middle of making the repair. I bought this car a couple of years ago which had the heads done by WCCH/Vengeance Racing (see attached invoice). This was done about 25,000 miles ago. I had the car reflashed back to the OEM tune thanks to the liberals here in Colorado. Anyway, I’m thinking I should go back to an OEM spring (or same spec) just for peace of mind. Any suggestions? Thanks!
Undy nailed it. Stock springs have been tested to 7,000rpm+. No need to tempt fate on even more sideloading of LS7 guides by going to stiffer springs on a stock cam. Are you worried about over revving, or???
I’m worried about digging into this engine again! Just a weekend toy car. Looking now for new springs. I guess I should go back in with stock push rods too.
hiznhrz (12-11-2023)
I would definitely go with at least an .080" wall, 3/8" diameter hardened pushrod.....
Not completely sure about that. This “head repair” was completed 9 years ago.
I spoke with Vengeance Racing and they couldn’t advise any further other than explaining they probably cleaned up the surfaces and still remained within “specs” for the ZO6 heads while keeping the stock cam.
They now send out heads for this type of work.
Lifters were LS7s. Upon purchase about 12,000 miles ago, I switched to Amsoil 5W-30. Changed at about 4200 miles intervals.
I have a new set of GM LS7 lifters and waiting on a new OEM LS7 cam. Trying to justify the $700 - $800 for Johnson lifters at the moment.
Understood. However, this is what I’m trying to avoid; changing things too much in this car. No real modifications other than “repaired” heads.
Winter is upon us so I have plenty of time to figure this out.
You cheap out on these cars, you pay way more down the line. Heavy lesson learned.
Let me say up front that it's hard to say anything bad about Johnson lifters. One of the very best, if not THE best. But the question is whether or not you need a set of $800 lifters in a pretty much stock engine. Now, I'll give you my experience. I have a modded LS7 in my C5. Running PAC dual springs with 425lbs@max lift, 165lbs on the seat. Running genuine LS7 lifters and genuine GM trays. Cam is spec'd by Futral, ground by Cam Motion. It has .603"/.608" lift, 232°/250° duration, on a 112° LSA. I have 52,000 miles on the build, never a problem with the trays OR lifters. I have a 7,000rpm shift point.
The following 3 users liked this post by grinder11:
1972bluelt1 (12-14-2023)
Aftermarket springs would be an option to consider if you moved to a SS exhaust valve as so many of us do. more weight requires more spring control for the valve.
