[ZR1] Need a fuel pump - 2013 model
Cruise-In I Veteran
National Champs Gators 4 St. Jude '09
I need a fuel pump assembly, GM Part # 19420818
I've searched multiple threads and have not found the answer to this one.
Does anyone know of an aftermarket solution for this item?
Thanks in advance.
Blue Thunder
ACDelco 19420818 Genuine GM Parts Fuel Pump Module Assembly
and it would appear there is a national shortage, backorder, whatever you want to call it. Haven't been able to find it for months.I've searched multiple threads and have not found the answer to this one.
Thanks in advance.
Blue Thunder
Thanks in advance.
Blue Thunder
Thanks in advance.
Blue Thunder
Did you figure out a solution? What is wrong with the module. If it is the pump we can probably replace the pump itself. Not sure if the level sensor is the same as on the standard C6 and Z06 pumps. If it is we could swap the level sensor. But if you need an entire module then that is more difficult/expensive since they are hard to come by (and expensive when you can get them).
LS9TA (01-08-2024)
Latest word from Summit is March 11/2024 ship date. Don’t hold your breath as that date has been moved back 3 months at a time for over a year now.
Recently checked with Summit to see if my original order was still in force, it was not. Also noted at that time that you weren’t even allowed to place an order anymore. Signed up for a notification if part became available. Last week an email notification arrived saying the part could now be ordered with a ship date of 3/11. Who knows..
Bill
Florida
Bill
Florida
LS9TA (01-08-2024)
The DW400 does flow more than the OEM Z06 pump but you will have to disable the venturi pump to run it (I don't think they offer a version with a secondary feed to drive the venturi (jet) pump.
Bill
Florida
Bill
Florida
Konadog06 (01-09-2024)
https://www.ebay.com/itm/11602336219...mis&media=COPY
is this of any use? Perhaps this can be swapped In
Cruise-In I Veteran
Had one on order with GM dealer for 10 months and they came back and said the order could not be fulfilled....and they don't even know if it ever could. So, going the aftermarket route.
You could look at Lingenfelter or Racetronix they have pumps for sale - what is in stock I do not know.
Now on a Z06 it is a different story since that used a conventional brush type pump. But I think those modules are also much easier to get.
But those pumps won't work with the OEM ZR1 fuel pump controller since it is expecting a brushless DC pump. You would have to change to a different fuel pump control module and then configure the vehicle to accept that module (or disable the module).
Bill
Florida
Bill
Florida
https://www.corvetteforum.com/forums...fuel-pump.html
Are you saying your car has been disabled since April due to the lack of a fuel pump?
You could conceivably put a normal c6 or something like the lingenfelter e85 pump module in a zr1 and make it work. The fpcm can be turned off in the tuning software. It would take a hotwire pump harness and a signal from the fuel pump relay to turn it on. You will have to alter the tune because the zr1 commands different pressures based on load. But at least you could drive the car until/if the zr1 module becomes available again
