How much nitrous can my Ls7 handle
First time asking a question on this forum, hopefully I do it right. I own a 2008 z06 and I was trying to see what's the most I could push my car as far as nitrous. My ls7 will have a forged wiseco pistons, frankenstein f710 heads, RPM B3 cam, MSD ported intake and Ported nw 102 throttle body, Cold air intake, 2 inch headers and a rxt 1200 clutch. The goal is for the car to hopefully push around 600-650 whp (im hoping). With all that being said what would y'all think my limit is on nitrous. I was hoping for a 200-250 shot to put her around 875 whp. I will for a fact make sure i spend the extra bucks to make sure I have all the equipment to run nitrous properly ( bottle heater, wiring harness, launch and timing control, dedicated fuel cell, window switch ect.).
You didn’t say what rods your running .
from what I’m reading your having your ring gapped for nitrous
if running a plate system I wouldn’t run over a 200 shot (due to distribution)
most people who runs direct port system runs over a 200 shot,you call the shot
this comes in handy to
a wide band
a wide band
It’s a stock bottom end just with just pistons. Mechanic had mentioned my rods should be good , don’t know how correct that statement is though.
QUOTE=Last 1;1606659297]You didn’t say what rods your running .
a wide band[/QUOTE]
a wide band[/QUOTE]
Many have ran 200hp without issue. I ran 150-180hp for a year or so with no problems. Mine was a single nozzle, dry shot, tho. Just don't activate the nitrous at too low of an RPM.
I plan to run 250hp on a hi ram plenum plate here soon.
You just have to understand blowing motors is apart of the game. A lot of variables that can blow a motor modified and even being stock. But I know of two people who have ran 1100+ boosted plus a shot with just a forge piston ls7. Make sure you have ring gap and tune is on point. On a ls7 I’d do CA625 head studs.
Remember, more power equals more problems. Hope you have the funds to replace the block when it breaks from a cracked sleeve.
Been there, done that.
more power more problems
more money more problems
“Knock on wood”
I’ve ran a ton of spray through my Sbe Ls7
The right tune and controller, it’s safe. Yes you can have catastrophic failure if something fails.
But that’s the fun part 😎
Food for thought my car made on a 200shot (Nitrous outlet 102 plate system) on E85
H/C max effort . 767rw
Well that’s expected
“Knock on wood”
“Knock on wood”
