[ZR1] ZR1 - Replacing Shocks - Need Advice
So my mag ride shocks are bad and need to be replaced. I had decided to avoid spending a fortune on new mag ride shocks, if I could even find some.
I was able to locate a set of the DRM valved Bilsteins and had planned to use those. I am now however second guessing myself since I can't find anyone with a ZR1 that has gone with these shocks. Seems most of the folks who have gone that path didn't have the mag ride to begin with.
Am I insane for NOT breaking my neck and my bank account to locate a new set of the oem mag ride shocks?
Or since I have a set of these DRM Bilsteins, am I insane for not using these and having the mag ride turned off with a Tech2?
Thanks in advance,
Matt
Thanks in advance,
Matt
It sure is a bite in the butt to buy an expensive ZR1 with that special feature and then not being able to source reasonable priced OEM like replacement shocks. The limited number of C6 ZR1's likely means an aftermarket vendor wont see the profit in bringing a replacement to market. Lastly, i understand the oems are not even rebuildable.
Received 8,876 Likes
Curious how you know your mag ride shocks are bad? There are a lot of reports of dealers and shops claiming they need to be replaced because they are "leaking" but turn out not be to the case.
BigBilll (05-12-2023)
thing knower
i got my new ones from rock auto, don't bother searching for the nut tool though, I've got 5 that don't fit even though they said they would .....
id recommend staying with the oem stuff...
one of mine was definitely busted, started leaking gray paste out of somewhere.
you will see fluid down to the lower control arm bolt is bad... if it's half way or less with the oil, the shock is fine....
https://www.rockauto.com/en/catalog/...k+/+strut,7556
The following 2 users liked this post by drewz06:
Cone killer (05-17-2023),
Joey D (05-13-2023)
Perhaps these are stil available... https://www.corvetteforum.com/forums...10k-miles.html
I'd stay with OEM MRC shocks. Anything else would be a letdown, IMO.
I appreciate everyone’s feedback and advice. That is one of the things I love about this forum.
I think since I have the DRM Bilsteins, I am going to try those out. Lots and lots of Base, GS and Z06 owners love them.
I certainly don’t plan to hack up the wiring so if they ride like crap and it turns out I hate them, I will then go on a mission to find some oem shocks.
Thanks again!! 🍻
Thanks again!! 🍻
Thanks again!! 🍻
Thanks again!! 🍻
If you are primarily going to be street driving, I'd definitely stick with the mag ride but if you want something that can really maximize your handling either for track or Sunday mornings, there are some good options available.
Received 4,738 Likes
You will need a "tune" in your BCM if you go with standard shocks to turn off the active dampening
