[Z06] 2007 Dropped a Valve
Just for data input if anyone is keeping track.
2007 C6 Z06
Corsa Axle Back
27K miles
Bone stock otherwise, down to the filter.
I’ve had the caged go fast C6Z once, and decided to buy another and stay stock and just enjoy the car.
Well, stretched her legs out, top of 3rd she popped, big white puff out the back, I stomp clutch, too late, tach fell to zero, that was that…
Towed her back home, ordered a 2013 GMPP LS7, did the swap, have a 3yr warranty, once that’s up, she’s getting the H/C love…
Heart Surgery
On her way home….
Off with its head
New toy in a box
Dear Bruce..
Ouch
Yup
Offfff
Offfffff
She’s home, enjoying her meticulous break in period with BR30 juice
2007 C6 Z06
Corsa Axle Back
27K miles
Heart Surgery
On her way home….
Off with its head
New toy in a box
Dear Bruce..
Ouch
Yup
Offfff
Offfffff
The following 3 users liked this post by LouBdub:
American Heritage (04-24-2023)
Sorry that happened, good to see you got it taken care of. I'm sure Bruce Ackerman would be sorry to hear about as well. He assembled the motor, but the heads were provided by Linamar:
https://www.linamar.com/
Let's give credit where it's due. CEO of Linamar Linda Hasenfratz.
Speaking of LS7 heads, it would be interesting to look at the valve stem to valve guide clearances of the head that dropped a valve. To date no one has done that and reported the results. It would shed some light on the LS7 loose valve / valve drop issue.
KnightmareLS1 (04-25-2023)
Received 3,089 Likes
2021 C6 of the Year Finalist - Modified
Looking at your photos of the damage, I see that the exhaust valve is what failed.
Since the LS7 exhaust valve is a hollow stainless steel / sodium filled valve, I am thinking that the head of the valve just snapped off the valve's stem ... and then that valve head banging around in the cylinder just destroyed the piston, head and cylinder wall.
What a mess !
__________________________
Seems like everyone is so concerned with the LS7 hollow titanium intake valve failing, we now see there is also a big problem with the LS7 exhaust valve too. I think a good fix for the problematic hollow stainless steel / sodium filled LS7 exhaust valves is a set of solid stainless steel exhaust valves (as what's used in the LS3).
What a mess !
2007 C6 Z06
Corsa Axle Back
27K miles
Heart Surgery
On her way home….
Off with its head
New toy in a box
Dear Bruce..
Ouch
Yup
Offfff
Offfffff
2007 C6 Z06
Corsa Axle Back
27K miles
Heart Surgery
On her way home….
Off with its head
New toy in a box
Dear Bruce..
Ouch
Yup
Offfff
Offfffff
LouBdub (04-25-2023)
The ZO6 is a car, I would never buy. If it is not the heads, then you have the rods to worry about. Crying shame. It is a great car.
Did GM ever update and revise these ls7 crate heads? I just bought a z06 it had the engine replaced 2 years 13,000 miles ago, with warranty. Should I "fix" the heads when the warranty ends?
Bean counters, MBAs and lawyers.
I’m lucky enough to be in a position that buying a LS7 crate made sense. GM gives it a 3 yr warranty since it was installed at the dealership and was a direct OEM replacement.
So I’m happy to drive it.
Once that’s up, she’s getting some extra love
The following 5 users liked this post by LouBdub:
dmuellenberg (04-25-2023),
DougHG8 (05-01-2023),
Landru (04-25-2023),
Slick427 (04-25-2023),
wjnjr (04-25-2023)
2007 C6 Z06
Corsa Axle Back
27K miles
Heart Surgery
On her way home….
Off with its head
New toy in a box
Dear Bruce..
Ouch
Yup
Offfff
Offfffff
2007 C6 Z06
Corsa Axle Back
27K miles
Heart Surgery
On her way home….
Off with its head
New toy in a box
Dear Bruce..
Ouch
Yup
Offfff
Offfffff
Sorry for the loss bud. This is what the valve drop looks like when it does drop. To the peeps who say the valve drop doesn't exist, and that the fix actually fixes the issue. The only fix to correct the valve drop from happening is replacing the OEM crap with a TFS aftermarket head. They are the ONLY head manufacturers who get completely away from the OEM perch and geometry. A valve dropping into a cylinder isn't an if but more so a when. If I were you I would swap the new heads off the long block say screw the warranty, drop the OEM castings in the trash and get a set of MMS 265 castings in their place.
I almost suffered the fate you have 2 times by trying to have the "fix" done
Want it fixed right?
go have a talk w @Tony @ Mamo Motorsports let him give you the skinny on the fat.
Philkilla (04-30-2023)
Tony will be the one I go to for heads, but not until my “new car” motor warranty is up. I don’t care what it does during the warranty period, it’s not on me. Just gonna drive and smile.
The following 4 users liked this post by LouBdub:
Yeah I purchased what was my dream car the 60th Anniversary Edition and the dealer had just put a crate engine in it I've had it 2 years and put 2000 miles on it but I think I need to have heads done even though it has a rebuilt crate engine. The engine alone was $14.5k so my buddies keep saying I have a ticking time bomb
Slick427 (04-26-2023)
Yessir GM never legally owned up to it. So basically if you get a crate engine realistically you're purchasing same problem only it more cost effective give attention to the heads. Then the real issue is do I completely replace the head or have it repaired and the real true answer is to just do away w the head because of the geometry of the head sell the old ones and purchase a new set from someplace else like AHP or Katech or Frankenstein. I have to do mine this winter and I'm still up in air about it sucks
