[Z06] Engine builder inputs (DCR, cyl pressure, cyl heat, knock)
#81
Yessir. I’m curious the outcome once he reduces compression with those pistons if the 2k rpm issue is still there. I have a feeling mine is too high but would love to cross it off as yup that’s what it is vs guessing. It appeared after swapping to a smaller cam so higher dca
#82
#83
Have they measured the bore in the block is it out of round. They can recoat pistons does add like .001 or .002 to the piston. Do you have any photos of the pistons tops as taken out - Oh I see them on page 3? Was motor using oil at a more than normal rate like a quart every 500 miles etc.?
Engines been a part pretty much every winter. Ive been fighting valve guide wear after putting in a copper based sleeve (K-line) in the valve guides together with the stock intake valves. Last year i finally got fed up with it and went with AHPs TI valves and Moldstar90. Going to have my head guy check them out in a week or two, hoping to find everything to be in order.
Car was bought as a HCI car with a BTR 4 camshaft in it and stock pistons. Was lead to believe the stock pistons were crap and had them replaced first winter.
Yeah. Sad thing is it could be a multitude of things, like the intake seals/ports being messed up, or compression, or both... Now, since I'm changing multiple things at once, i wont be able to say 100% what caused it.
But I totally agree, sadly I'm often finding myself looking way to much into an issue, that really isn't an issue.
#84
#85
I hear you there - just annoying pulling 8-10deg from the timing map in the 2k region to stop it from happening - im sure I’m losing torque.
#86
Another situation in which the J&S Interceptor would work wonders.
#87
#88
