[ZR1] Wanted Ls9 accessories
Sitting on a shelf I have the following OEM items from my ZR1/LS9 (~50 kmi). My car's only aftermarket mods were a 2.6" upper pulley (with required 100mm driver's side idler and replacement green blower belt) and 90mm TB, so nothing to severely overpower or stress ancillary components. All these parts were operating normally when removed, however there are no guarantees expressed or implied and YMMV:
Starter
Alternator
Exhaust Manifolds
Oil Cooler with block hose and radiator hose (complete)
3.100" Dia LS9/TVS2300 Pulley (OEM)
LS9 Harmonic Balancer
LS9 Flywheel with ZR1 OEM dual disc clutches and hat (complete - never smelled burnt clutch; never slipped to my knowledge)
Oops,, Didn't see you requested a PM... Too late now for this stuff, but I know I have more that Ill PM if I go downstairs and look on the shelves. Is this the sort of stuff you're looking for?
Starter
Alternator
Exhaust Manifolds
Last edited by Itbites; 11-26-2022 at 08:00 AM. Reason: Missed OP's request for PM...
Hey man, I have a Kong X Ported Stock blower with Lingenfelter Snout and a few of the front accessories like the following:
Alternator, Alternator Bracket, Kong Tensioner, Stock Damper and IW Overdrive Damper, A/C Compressor, Front H/E, Factory H/E Pump with some lines, Kong Air splitter that goes into the lid, and a DSX Aux Fuel Pump Kit as well
