Amsoil or Joe Gibbs Driven?
The only folk that tend to believe mobile one is fantastic are the same ones that wear jorts and new balances at the car meets- the same ones that believe in the oil fill cap that read mobile one……I guess perception is reality.
M1 had a contract with GM to factory fill their cars. Nothing special. Their marketing team did a great job to milk it as a great oil.
marketing is sales and spec sheets are facts.
If you care to know how engines work and what moving parts touch inside your engine, you’ll care about zinc and phosphor levels and that they are important even on modern engines.
zinc and phosphor were cut by the bullshit epa. In the late 90s or maybe 2000s, the level of zinc and phosphor dropped considerably.
If it was my engine, I'd run a good conventional, non synthetic oil for the first 750 miles. I'd also try to fit a magnetic drain plug in the oil system/sump somewhere. I have a wet sump LS7 engine, so don't know where or what you'd do for a magnetic drain plug in the dry sump LS7. I'd then change the oil and filter, and fill it with a good synthetic oil. I'd recommend Mobil 1, but some guys here seem to think its marginal, and not "fantastic." BTW, if you do happen to find a "fantastic" oil, please let us all know. Sorry for the sarcasm, but some guys here.......Anyway, I've run M1 for over 20 years, and at least 50 dragstrip runs. I have 52,000 miles on my current, 600+ hp LS7, and use-MAYBE-1/2qt. between 4,000 mile changes. Nothing but M1 0w-40. No oil related issues, EVER!! I also have no vested interest or stock in Exxon/Mobil. My opinion only.....
As a service advisor I have no hesitation to put it in a newer non performance car. My hesitation was it’s such a specialized engine. Why run 40 in it?
Engine OIl To Run IN A Newly Built LS7
Must use NONSYNTHETIC oil for the first 1000 miles.
Joe Gibbs BR30 (10w-30) break in oil Recommended.
Change oil before dyno tuning
Change oil after first 500 miles
Change oil again after 1000 miles
After 1000 mile break-in is complete, full synthetic oil is permitted.
So apparently, LME thinks the oil selection is important during the initial break-in, which is primarily for the rings.
Pro Mechanic
Pro Mechanic
My engine builder (Late Model Engines of Houston) is completely definitive about this. and I quote:
Also, know that JGR sold the Driven deal a number of years ago. Driven Racing Oil is now owned by COMP and no longer uses "Joe Gibbs" in its branding. Finally the guy Coach Gibbs originally hired to formulate the original Gibbs DRIVEN products, Lake Speed Jr., left the company after Driven was sold and is now working for Total Seal Piston Rings and, also, has his own oil analysis business, SPEEDiagnostix. He's also active on YouTube with a whole series of informative video content on engine oils.
The following 2 users liked this post by Hib Halverson:
tommyc6z06 (01-16-2024),
Vito.A (01-16-2024)
Can you describe the type of ring package and the cylinder wall preparation in more detail? I'm interested to know that info because the need for a break-in oil is often driven by the type of rings and the bore prep.
Break In Oil
Bore (in.):
4.030 in.
Bore (mm):
102.362mm
File Fit:
Yes
Gapless:
No
Gas Ported:
No
Top Ring Included:
Yes
Top Ring Thickness:
1.2mm
Top Ring Material:
Steel
Top Ring Facing Material:
Gas nitrided
Second Ring Included:
Yes
Second Ring Thickness:
1.2mm
Third ring is a 3 mm oil control ring.
As to the cylinder wall preparation, I am pretty sure that if I asked, that LME would tell me that it is proprietary information. I am very sure that LME knows what they are doing.
