22k mile ZR1 first time owner
Hi All,
I just got a 2013 ZR1 with 22k miles on it. It is a supersonic blue with blue stitching w/ ebony interior.
Being new to these cars, just curious what everyone recommends on maintenance or things to look out for?
A couple things I have questions on:
1.) I need to replace the rear inner fender well pieces that have the flare sticking out on the back side, seems one is slightly torn at the bottom and the other looks scuffed. does anyone have a part number?
2.) Are there any fluids recommended that I should replace immediately for proper maintenance?
3.) Is there any way to tell how many supersonic blue ZR1s were made? w/ blue stitching?
4.) Are there any concerns to keep a lookout on?
5.) Does anyone know what was the proper floor/hatch carpets that came with the car? Looks like the original owner put in all-weather rubber mats, and I want go back to the original mats.
6.) is there a way to order a new owner's manual set (cover, etc...)?
7.) any easy performance mods suggested?
I apologize if this all has been asked before... I did search and found A LOT of information not exactly pertaining to my searches.
Blue Stitching: 74
Ebony Interior: 279
https://www.corvetteactioncenter.com...-zr1-registry/
Jim
When I buy my 2012 with 11k 2 and a half years ago I change the fluids in the trans, brake, diff, and also the coolant so it’s all reset to zero. If you are not aware of the isolator coupler issue you can check for play on the upper pulley by loosing the tension on the serpentine belt other than that these car are almost trouble free and bulletproof. Congrats for your SSB Zr1 one of my favorite
Supersonic Blue 2013 ZR1's: 12
Blue Stitching: 74
Ebony Interior: 279
Jim
Blue Stitching: 74
Ebony Interior: 279
Jim
Is there a good site that sells OEM parts for our C6 still?
It looks like I need to get a replacement fuse box cover in my engine bay, as the one on it no longer stays closed, as someone broke it (also noticed it doesn't close properly, not sure if this is a common issue?)_
Your local Chevrolet Parts Department if you're in a hurry or any of several online GM Parts vendors if you're not
I agree with captain vette.
I would also change the power steering fluid.
If you have a problem with the clutch pedal sticking to the floor (common issue) like mine, upgrade the clutch master cylinder to the GM upgraded one. Just use your existing clear reservoir instead of the new black one.
I went with the Tick master cylinder a few years ago & have zero issues even with HPDE.
Congratualations & enjoy!
I purchased a 2011 ZR1 about 6 weeks ago and did all of the above and in my case, the boots were almost baked on the plugs. The boots did not need to be replaced most likely but I replaced them with OEM. You can find my thread as I just did this...
A good local parts guy and a service guy are worth their weight in gold. It really helps to build that relationship.
You have a rare car. There were only two 2013s made in Supersonic Blue with ebony/blue stitching. Their VIN numbers end in 087 and 173. Yours should be one of these cars if the registry is correct. Both of these cars were optioned with black headlight color override which means your lights should be black, not supersonic blue.
Whoop (04-02-2022)
Received 4,731 Likes
A complete fluids change out would be my first order of business
