Ultimate Permanent LS7 Head Fix for those who...
1/4 mile/AutoX
Are you using condescending language to ""criticize" the LS1/LS6 platforms? I would wager the C5 Z06 has far fewer catastrophic engine failures, and class action lawsuits, as well, than the C6 Z06. I have a built LS7 in my C5. I wish I'd never changed the original engine.......
I disagree. If a product is engineered correctly, from a clean sheet of paper, power output will have little effect on reliability. In an all out racing engine, yes, higher rpm/power are commensurate with a decrease in reliability. In other words, modify the existing platform of the LS6 to achieve a 505hp output to match the LS7, yes, reliability of the LS6 SHOULD be less than it is at 405hp, and less than the the LS7@that same 505hp level. As for the LS7 not having any issues if it was the same power level as the LS1, I disagree again. If you use the same inferior vendors, materials, engineering, coatings, and machining, problems would exist at the same 345-350hp as it does at the 505hp level. Power output of a stock LS7 has nothing to do with the failures owners have experienced. I do agree that modifying an existing platform and expecting the same reliability as it had in stock form, is not realistic. But the LS7 in stock form SHOULD be just as reliable as the LS1 is in stock form-IF ENGINEERING, MACHINING, AND MATERIALS are of equal quality as the LS1 had. If GM didn't expect that, they wouldn't have offered the same, or better, warranty on the LS7......
Pounder (11-18-2021)
The thing is they DID just modify the ls1/6 to have 505hp…that’s literally the definition of the LS7.
Same engine with bigger bore, bigger stroke, and higher flowing heads.
They added Ti parts because the design of the LS1 engine needed them for it to spin that high / breathe that much and make the 505hp while sticking with emissions regulations. They also wanted to test out some exotic materials and coating technologies on a low production engine. Clearly they learned a lot from the LS7 as things kept changing as we progress through the years of LS/LT having Ti and fancy coatings.
Now they have a new engine with the C8Z and are using lessons learned from before to design the parts inside.
1/4 mile/AutoX
Selim Bradley (02-08-2022)
1/4 mile/AutoX
Sorry to AHP for wrecking your thread !!!!
Hey at least you bumped the thread for ‘em
The following 3 users liked this post by grinder11:
LS7_guy (02-26-2023)
#34
The Archangels are 12 degrees.
#35
What is cost for these heads -- assume no trade as owners may want to keep the ls7 heads moth balled to go with the car at future sale time
The following 2 users liked this post by Apocolipse:
Selim Bradley (02-08-2022),
Z.06 (11-21-2021)
#37
Received 3,089 Likes
2021 C6 of the Year Finalist - Modified
Maybe I am wrong, but how would LS3 heads even fit on an LS7 ?
The angle of the rocker arms are completely different between the LS3 and LS7 heads (I know for a fact that the rocker arms are not interchangeable between the two engines) ... and it has nothing to do with a 1.7 rocker ratio vs a 1.8 rocker ratio rocker arm.
#38
They said right at the end of the post you have to run an ls3 manifold to make it work. I'm assuming needing ls3 rockers was a given. I think the multiple qc issues are what plagued the ls7. I firmly believe there would be no examples at 100k+ miles if there was an engineering flaw with this motor.
#39
#40
That is kind of a confusing statement for AHP to make, isn't it? Good point, as I also thought their LS7 heads were "the fix". Kinda strange to say 'our fixed LS7 heads are a top notch fix', but then later say 'if you want a "permanent" fix, don't go with them, go with these'!??!
