[ZR1] Zr1 rear badge placement
My rear badge has been crooked since I purchased the car new, and I’ve been thinking about buying another badge and straightening it. I’ve noticed many stock crooked badges. So my question is could anyone post dimensions on there straight one? Like how far down from the taillights and how far off center of them?
thank you
thank you
The OEM badges are pinned to fit in factory drilled holes. Only one way to install. Either a bad badge was installed when built or the holes were drilled wrong. I don’t believe aftermarket badges have pins
Ed
Ed
are you sure? The rear fascia is the same part number across all trim lines, so none have holes as far as I know?? I also ordered a new badge and while it looks as if it had pins at one time or a provision for them the OEM part came with a small radius to match the rear fascia.
the rear OEM badge is 25858635
the side OEM badge is 25858633
the rear has no pins and has radius.
the rear is also noticeably thinner
the side badges are the same number for both, and I have not ordered those, so maybe those have pins. Maybe someone more knowledgeable will post up.
would someone be willing to take a few measurements of the rear badge location? Please
thank you
I would look at a few other ZR1's or some pictures. They all look crooked. I looked at mine and it appears twisted slightly left. I also looked in my 2011 service manual and the only emblems that use alignment holes are the Corvette emblem in the center of the front and rear facia. The Z06 and ZR1 emblems don't. In the old days service manuals would give measurements so body repairs can be done and emblems can be applied in the correct location. My service manual does not have these measurements and doesn't even show the ZR1 emblem on the rear facia.
Gypsy883 (05-05-2021)
i agree most, if not all, do look crooked. Mine is twisted slightly left as well. Slightly annoying. It’s almost as if they just had someone stick them on “close enough” when built.
Just wanted to get a reference point.
I found this in a search. Wonder if they are all close to these dimensions.
https://www.corvetteforum.com/forums...placement.html
OP, apologies about the badge pins info. I thought you were talking about the flag badges. My rear ZR1badge is 1/16” lower at the blue 1. Not going to change it for 1/16”.
Ed
Ed
thank you
thank you
The R falls directly below the centre of the two tail lights, 8” from the bottom of the tail lights to the top edge of the emblem. Bottom edge of emblem is 3 1/8” above the transition between body colour (white) and black rear valance.
Hope this helps.
Gypsy883 (05-08-2021)
Here’s some pics of mine that is stock and straight.
Hope this helps.
Hope this helps.
Thank you!!!!!
Received 3,095 Likes
2021 C6 of the Year Finalist - Modified
It's perfectly centered between the two tail lights, but, it just don't look straight to me ... Seems like the right side of the emblem is a little too low.
I think it needs to align horizontally more with the tail lights (forget about alignment with the lower black plastic diffuser ... it's angled slightly anyway).
