390 gears
Pros: makes the car snappier, more ideal for 1/4 mile (if NA), can help big cam drivability a bit.
Cons: harder to find traction on the street, cuts your 4th gear top speed down a good bit for roll racing or half mile stuff.
Cone killer (11-04-2022)
first ? are you NA if so by all means go for it. your only problem is keeping the smile of your face for doing it .I was running 4.10s in my car and moved up to 3.90s with my car if I decided to run NA I can run a 26” tire and go thru the traps about 140/and if I decide to turn my bottle on i can go to my 28” and try to shove it thru @ 150(1/4 mile)
double06 (05-11-2021)
Cone killer (09-12-2022)
I'm running 3.90s with thier stage 4 diff. You'll be at the top of 4th in the 1/4 when before you were top of 3rd, bottom of 4th. You'll be top of 3rd in the 1/8th on a 26 inch tire. If you have a big cam it makes it easier to drive in the street as well. From what I've been told by rpm, if running a 26 tire go 3.90 of 28 go 4.10.
