[Z06] What valved axle back options do I have?
Guys,
The Hooker system looks interesting. How is the drone with that system.....I HATE drone in the car.
This is why I was considering sticking with stock and just building custom cut outs. No drone cruising and you get the volume and the flow at WOT with the flip of a switch or even a vacuum operated cut out valve.
Pretty sure the Fusion exhaust has drone from the research I have down.....I also wasn't aware of the Hooker system until today and its interesting. I would recommend this system to my clients. Seems reasonably priced and has the large 3" pass through
Modding stock mufflers to a full 3" is alot of work.....the Hooker system has it all done for you
Good stuff....curious if you guys that own the system are still happy with it and your thoughts on the dreaded drone....LOL
Regards,
Tony
Regards,
Tony
__________________
Please take the time to also visit my website at www.MamoMotorsports.com
the question really is if there are any performance gains (even lower exhaust temp. would be one) to be had with these systems or if it all about sound.
A modded engine will be held back with the OEM exhaust.....it necks down to under 2.5" in the OEM muffler (some say 2.25" in fact....that's waaay too small).
Never had one apart to quote with confidence but I have read about the choke in the OEM muffs many times
I mean if your making over 550 at the wheels (650 at the crank), which is 100 more than stock, there are gains to be had with a higher flowing catback
If your making even more than that the gains would be larger.....a stock motor wont benefit a whole lot but a modded engine with good heads and a free flow exhaust (headers/ X-pipe etc.) would definitely benefit
-Tony
-Tony
Guys,
Regards,
Tony
Regards,
Tony
As I mentioned in my previous post, the fitment is not great. I plan to take mine to a local fabricator I trust to get the tips perfectly straight and symmetrical. I'm pretty picky though. I gather you're pretty detail oriented as well, based on the couple of conversations we had on the subject of cylinder heads...
Because I'd rather have 3" and make 1305 rwhp.
Received 4,782 Likes
I had a Z06 with Billy Boat headers catless x pipe and axle back exhaust including the valve system. It was obnoxiously loud with the valves open and not much better with them closed. Fun for about 15 minutes and than exhausting to drive. I ruined that car between the exhaust and the BTR Stage 3 cam. Smelled like a gas bomb🥴😳 Ive heard alot of good things about the Corsa exhausts...
Also why it was obnoxiously loud. Put a set of high flow cats on and you would like it much better.
