Stock C6 Z06 Intake vs. CAI?
I have installed cold air intakes on other cars and from what I have read a CAI is a good mod for the C6 Z06. From online pictures I can't tell how they actually work because they look very similar to the stock setup. Do CAIs involve cutting into the ducting to actually get cold air? In other words, how does a good CAI differ from the stock Z06 intake? Thank you in advance.
Rob
Bone Stock 2009 C6 Z06
Rob
Vararam CAI you have to cut the shroud. See if you can pull up installation of a Vararam that might show you how it works. Had one on my C5 and have one on my ZO6. They are a true CAI.
RobRobinette (02-02-2021)
gren01, I took your advice and found a C6 Z06 Vararam install video and it showed me exactly what I needed to know. Thank you for the suggestion.
rgeorge33, I watched the video. It seems all the "cold air" intakes tested did not cut into the radiator shroud like the Vararam does to source cold air. It seems they all pull in the engine bay air like stock except they breath better. Is that true?
Received 4,782 Likes
I found this to be helpful when looking at intakes: https://youtu.be/3EgXNEvIDg4
Looks like an older Halltech too with the sensor close to the air coupler. New ones are a little further forward.
Agree that it doesn't get a lot of direct cold air without cutting. It does get a small amount through the functional NACA duct and from around the sides of the front plastic. As I understand the design GM engineers limited direct airflow to limit MAF turbulence. I also have the Airaid, but haven't done any dyno work to quantify its effectiveness.
For those with a CAI and especially those who have cut around the intake as seen on the Vararam, are there any issues regarding the rain? Still doing my research as I anticipate buying a Z soon, and would likely be driving in the rain. Wouldn't want to get into a H/C/I Z only to realize it's a hazard when the water comes out.
2023 Corvette of the Year Finalist - Unmodified
2022 C6 of the Year Winner - Unmodified
Dumb question; wouldn’t cutting into the radiator shroud to steal air from there serve to marginalize cooling to a small extent? Possibly problematic for a track car?
Just wondering ...
Just wondering ...
tommyc6z06 (02-03-2021)
