[ZR1] C6 Hood venting
C6 Hood venting
Has anyone had a vent installed in the back underside of their hood? I understand I can put a louvered insert in, but I really do like the window. That being said, something to help vent heat out would be ideal and I don't think I would have to worry near as much about water getting in. On the rare occasion I catch rain.
I
Windshield is a high pressure area - at speed air will go INTO your engine bay instead of out. Bad idea. There is a reason it’s sealed.
Received 8,872 Likes
I can go over the physics all day for you but you probably won’t believe me anyways lol. Try it yourself - tape some string tufts there and see what they do and at what speed it starts going the wrong way. They were called cowl INDUCTION hoods for a reason.
Perhaps you shouldn’t assume what others know, don’t know, or their ability to understand information
JABCAT (11-15-2020)
Quite the smug response for simply pointing out that one of the most well-known names in modified Corvettes put an open hood bulge on their supercharged cars & that I, personally, have not experienced any issues driving my vehicle at high speeds.
Thanks for the responses. Cooling system upgrades are in place with much more coming. However I thought this was worth gathering opinions on.
You can see where the rubber seal/weatherstrip was removed. Cure all - no, but anything to let more heat out of engine bay IMO is a plus, also have a Halltech DRED hood that I had the vented insert installed in.
St. Jude Donor '10
Well, I've actually seen photos of Callaway testing at VIR with the pieces of nylon tape testing the vents on top of the carbon bulge. Ive never see a cowl induction hood with the reliefs cut in it that the Callaway carbon bulge has. They did their homework.
The base of the windshield is a hi pressure area. With a cowl induction type hood the only opening is to the air cleaner and so the air goes into the air cleaner. Now if you consider the rest of the base of the hood or a non cowl induction hood and remove the seal between the hood and the base of the windshield or cowl the air could go either way . It all depends on how much pressure there is at the windshield base and the engine compartment. Back in the sixties windshields were more vertical and created more pressure so cowl induction worked great. Today windshields are more laid back and don't create as much pressure. But engine compartments today are more packed and may create higher underhood pressure. You see more louvered hoods today. You hafta test to see what your particular vehicle does. Do the string test.
