[Z06] The Blue Bullet Project: My Quest for a 600-hp Street-Drivable LS7
#161
Hi Hib, I had my PSI 1511 springs replaced a couple months ago and had new Ti retainers installed, but have not taken an oil sample since. I would expect the new Ti retainers would wear just as the prior ones did and put Ti into the oil, but at fairly low concentrations of 5-8 PPM. As you may remember, I had the bottom end fully forged, partly because of Ti, but also because I was seeing some strange low oil pressure excursions. The engine seems to be working fine and I don't anticipate doing an early oil change or taking an early sample to see if there is Ti in it. I have not gotten any spring pressure tests back on my old (22K mile) PSI springs. I was hoping to have those to compare with your results.
Dave
Dave
#162
This Fall I'm going to have to do some testing. I'll remove some parts which don't have EOs, for example: I'll reinstall the stock throttle body and the stock air filter assembly. Then I'll flash the ECM with my stock calibration then road test. If the engine meets the idle stability necessary and will set the I/M monitors, I'll go test.
what was the outcome of this?
#163
Hi Hib, I have had my oil checked every 2K miles. After the head work the TI went from 0 to just registering, new retainers, and the following 2K miles was gone again and every 2K since then. I think this is an indication that this milage is okay for seeing changes.
Good Luck with your TI issue! 🤞🏻
#165
Pro Mechanic
Pro Mechanic
I have not worked on that project, yet. My registration renews in May so I have some time.
The obvious questions are: once I have the stock cal reinstalled....
1) Will the engine run well enough at the stock idle (about 600 rpm as I recall) to not misfire excessively?
2) Will it run well enough in closed loop to set all the OBD2 readiness monitors?
#166
Pro Mechanic
Does turning emission monitors off change that number?
Don't think there's any bandaid for the idle speed.
Good luck.
Been through enough BS with that car already!
#167
Pro Mechanic
Pro Mechanic
#168
Pro Mechanic
Pro Mechanic
Good luck.
#169
How did you decide that 5-8PPM was "fairly low"? I know you went to forged pistons and forged steel conn rods. What brand and CR of pistons? What brand of conn rods? What was done to rebalance the rotating assembly for the additonal mass of the steel rods? I'm on a road trip right now in Southern Nevada and away from the info at my shop. I tested all the old springs then called PSI and gave them the pressures I tested. They said the springs were "borderline", so I bought new ones. When I get back, I'll see if I still have the spring test data.
t!
t!
Diamond LS shelf forged pistons, ~ stock CR so with the .030 shaved heads about the same as before 11.7:1, dyno'd and tuned for 91 octane gas as befor. Callies Compstar 4340 H-beam con rods, Compstar forged crankshaft. I don't know all the balancing they did as WFO did the whole bottom end, but the crank and pistons are lighter than stock, dyno after the work was virtually the same as before, which is what I expected.
I saw your spring test post earlier and, while I had that in mind, your results confirmed I should had the springs/retainers/seals replaced as I run the engine harder than you do and CPR agreed 20-25K miles is about the max you would want to run the springs with the .660 lift of the K501 cam. I asked to have CPR test the old springs but do not have any results if they have been tested.
#170
Pro Mechanic
Pro Mechanic
As far as the Ti content in my oil–I took the car on a 2024 Caravan prerun trip i to Nevada. Was over to Henderson then out to Pahrump and finally back to Goleta. I now have about 1800 miles since the last Blackstone test. This Sunday I'm going to put another 150-200 miles on the car on a Corvette Club trip and then I'll sample the oil. If the Ti content goes down, I'll rule-out the rods.
X'ing my fingers.
#171
Good luck, Hib. You and I are due for some, dontcha think??!!!
#172
Do you remember how many miles were on the Ti rods at the time you removed them? 57,000 miles, about 24 track days and a good number of extended high speed runs and trap speed events.
I might have asked you this before, but if you're using 91-oct gas, why did you mill the heads? Realistically had the heads milled so if I sold it to an area with 93 octane, just a tune to pick up a little more power.
Wouldn't it have been better to take less CR and more spark?Ok, so your rotating assembly has less mass than before, but what do the rod/piston assemblies weigh now and what did they weigh before? A forged steel conn rod usually weighs more than a Ti rod. To have the rotating assembly weigh less than stock means mass had to come out somewhere. I'll add that my belief has been that, since GM admitted that the Ti rods were in LS7s to reduce the effect of the piston/rod assembly's mass' on oil film strength at BDC and TDC, going to a heavier steel rod is ok as long as you, also, go to a better oil–say...Red Line 0W40 rather than Mobil 1 5W30–and that the effect of slightly higher rod piston mass doesn't slow the engine's ability to accelerate that much. I haven't used M1 5W-30 since my first track day ( at ~ 13K miles) and 260*+ oil temps. I usually run M1 0W-40 Euro formula or Amsoil 5W-30 when it comes back from CPR. Just about the same power before/after the bottom end work and still 160 MPH trap speeds in the 1/2 mile and just at fast at 7500'DA up in Ely NV in the 1-mile trap.
Considering your cam is far more aggressive than what I run, I'd have replaced the springs and etc, at 25K-mi, too.Bummer. It would have been interesting to have those numbers so we could call PSI and ask their opinion. Springs replaced at 22K miles based on your test results, thanks. CPR normally would want the springs replaced in their modded engines that are really used at between 20-25K miles and I had no problem doing them at that time given my use..
X'ing my fingers.
X'ing my fingers.
#173
Hib, attached are the before/after dyno runs from the HCI run in April 2018 and the forged bottom end in September 2018, same dyno, very close on power and torque. The April tune looks like it was just a little more aggressive, but the car drives and traps just about the same.
#174
Pro Mechanic
Pro Mechanic
The chassis dyno data was interesting, for sure.
Clearly, your April fuel calibration was just a bit on the lean side, especially below 4500RPM. That makes a little more torque, but it also puts more combustion heat into the chambers. For the type of duty your engine sees–1/2-mile runs at WOT and so forth–you were smart to give up a very small amount of torque with half a ratio less AFR in exchange for a little less combustion heat, less tendency to detonate and better reliability/durability.
Since you posted the results as an image file, I downloaded it. I opened it with my image software, so I could use the app's "guides" to measure the differences. In the midrange, you've given up about 12-lbs/ft by adding some fuel. At peak torque, you were down about 10-lbs/ft. By 5500 there was almost no difference in torque.
Looking at the AFR data, the significant differences are below 4500-RPM. If your tuner wants to get into "splitting hairs", you could have him/her lean slightly below 4500, but not as much as it was leaned in April, but leave the fuel schedule above 4500 alone.
Two questions: t
1) Was anyone taking engine controls data during the test. If so, was there any knock retard?
2) There is just a slight difference in the correction factors–1.04 vs 1.03. It's been a really long time since I've run on a Dynojet so my lack of current knowledge of Dynojet's Winpep software has me not understanding why the slight difference exists. Can you shed any light on that?
3) So I clearly understand your use of the term "forged bottom end"...previously, your rotating assembly was stock, ie: cast-aluminum pistons, forged titanium rods and a forged steel LS7 crank. Your rotating assembly now, is Diamond forged-aluminum pistons, Calles forged steel rods and a Calles forged steel crank shaft. Have I got that right?
Two questions: t
#175
#176
Hib, you got my builds right. As far as adjusting down below, When I do straight line event I'd I'd only be below about 4800 RPM on the start in first gear, thereafter the shifts drop me back into the 4800-5100 rpm range. On a road course I suppose it could be enriched below 4500, but I don't spend too much time there. NicD (the tuner throughout my build adventures with CPR) knows I run 91 on the street and the engine is tuned for that. When I do events I do try to get some 100 octane to boost tank octane to 93-94 to minimize the likelihood of detonation. The pistons that came out after 57K miles did not show evidence of knock.
On the 1.04 vs 1.03 adjustment to SAE, on the April run it was 74*, 28.5 in-hg and 33.4% humidity; on the October run it was 74*, 28.76 in-hg and 52% humidity. It is quite possible that the one correction factor was 1.0345 rounded down to 1.03 and the first was 1.038 rounded up to 1.04, so perhaps not a full 1% difference.
Apocolipse and Hib, the tuner is one of the best LS tuners (and generally) in AZ. I know virtually nothing other than you don't want the Air/fuel ratio too lean. I tell him the type of performance events I do, the elevation (800' to 6500' for different events) and he does the tune that should work for me on the street and at events. I do know that cam'd LS7s do have that wavy torque curve, particularly in the 2000-5000 range. I had Pfadt 1 7/8' Tri-Y headers several years ago before I went to 2" ARH, now with OR X-pipe. The ARH had one big wavy torque in the 2000-3000 rpm range that the Pfadt's did not have, but the ARH were more than 50 lb-ft of torque stronger down low than the Pfadts.
#177
Pro Mechanic
Pro Mechanic
Apocolipse and Hib, the tuner is one of the best LS tuners (and generally) in AZ. I know virtually nothing, other than you don't want the Air/fuel ratio too lean. I tell him the type of performance events I do, the elevation (800' to 6500' for different events) and he does the tune that should work for me on the street and at events.
Finally, I was just looking at chassis dyno data from my car, and you're about 50-hp up on me because of your cam and your headers. I'm making about 545 SAE at the tire at 6200 and you're making 592 SAE at 6600.
#178
NicD is there in the driver's seat with his laptop hooked up on every dyno run (probably 24-30 over 3-4 years). It is likely he has/took/saw that data, but I do not have it. I did get the Dynojet files of all the runs on thumb drives and have them on my computer, but don't know if those contains any info you are asking about. If you think it does, I can send you a couple files to your normal email address (I think I have it) for you to look at Hib.
#179
Pro Mechanic
Pro Mechanic
The DynoJet run files won't help me. What I'd like to see is the engine controls data NicD logged during the runs, but it could be that he's not willing to share that stuff.
#180
OK, this link will give you an idea of NicDs tuning talent (and driving). https://www.corvetteforum.com/forums...n-his-c6z.html
