ZR1 Electrical issue HELP
Had a problem start recently and I don’t know if there’s a fix for it or what the fix is. Hoping someone here has had experience with it. I thought I tracked down these strange electrical issues to a bad battery. Replaced the battery and everything was good for a couple drives. Then it started again:
Shut the engine off and the car keeps running fire about 10 seconds after shutting off
Rear view mirror stays on (passenger air bag light, compass and green led)
Selective ride light stays on
Something behind dash is running too (fan on radio?)
Push button start light stays on
Anyone have any ideas or experience? These literally won’t turn off unless the battery is disconnected. If I disconnect, wait a while then reconnect these stay off. But once I run the car they stay on again. The only thing I’ve installed recently electrical related is a DSX Aux pump, but it hasn’t been activated yet
Mines done the same thing once after it was being tuned all day, i unplugged the battery for a few minutes and it never happened again, i have no idea why it happened unfortunately, I thought maybe the battery was really drained from it being at the shop all day, but who knows, both my zr1 and ZO6 have had odd electrical issues that sort of went away on their own.
Good luck, hopefully it's just something like a loose ground
Received 1,679 Likes
That sucks brother... Did you have this issues "prior" to the Aux pump...? Keep us posted..
No, but like I said the aux pump isn't even activated, just installed. IMO highly unlikely to be related, I'll pull the power on it later and verify while checking grounds
Did you check to see if your battery is getting charged properly? It's likely not an issue that works for 3 drives after replacing a battery and then acts up again.
Could be an ecu issue too, make sure all your fuses in the engine bay are in tight and connections under the passenger side floor board are tight. Check alternator connection
Ryne said it was nothing tune related, but I guess that doesn't rule out ECU issues per sey, but no codes being thrown either.
