Cam Motion Stg 2
corvettenutz (03-03-2020)
Drives pretty good, decent chop on cold starts, little surge here and there but nothing atrocious.
Power wise it pulls very hard pretty much anywhere in the rpm range, lots of mid range torque.
I started it cold for a friend of mine a couple of weeks ago and he about **** when he heard it lol.
I have headers no cats and b&b fusions..
MMWD13 (03-04-2020)
I'm running the cam motion titan stage 2.
I am also curious how the Cam Motion stage 2 feels. But Cam motion has two different cam cores, so just for clarification, which one are you talking about?
Cam Motion LS7 Stage 2 Cam
Or
Cam Motion LS7 Titan 2 Cam
Or
Or
Or
I have a CM cam that was very close to these specs. I can tell you it will drive nearly like stock with just a slight lobe. If you want more lobe then do a 116 +3 or 115 + 3
I have the Texas Speed 2.2 cam which would be similar to the specs of the titan 2 cam. Makes 553 and 493 on a mustang dyno on 92 pump gas. I would say the other cam would be 530 to 540 wheel depending on mods. Either cam would have very minimal surge but good mid range power some good lope at idle.
