[ZR1] What pulley to get without modifying intercooler bricks
Your setup is similar to mine, except I'm running cats on ARH headers, I made 662 on corn, but it is a conservative build. I went with 1050 ID's, duty cycle is around 50%, plenty of room to grow!
GX427 (03-03-2020)
Isn’t just pulling top of fender enough room?
GX427 (03-03-2020)
Just installed the flex fuel and injectors I’ll update numbers soon
12hp and 25 trq with 27* of timing lol on e75
I'm getting ready to order a set of Greg's new bricks. I'll gladly spend the $1100 to avoid any future failures. I will be selling a set of Greg's reinforced OEM bricks that I bought at this time last year. They have 4000 miles on them. I'm only running a 2.60" upper pulley and a Lingenfelter snout.
GX427 (03-04-2020)
GX427 (03-04-2020)
Ive seen the bricks leak reinforced but only because the cars got beat on with mulitple hits and not enough heat exchanger in the front of the car. Im at 940 rwhp and no issues so far but I have a water tank and pump with a BIG heat exchanger in front. Greg makes good bricks I just did some in Carlos car this past weekend and they fit perfect. So perfect I had to use silicone spray to make them fit. Alot of passes back and fourth 9 or 10 total. Can you imagine once we all get ahold of the dual pass lids? Game Changer!
GX427 (03-04-2020)
GX427 (03-04-2020)
