[ZR1] Stock 2011 ZR1 only makine 9psi of boost?
06-09-2019, 11:58 PM
Problem was figured out.
06-10-2019, 04:52 PM
Quote:
Originally Posted by
JacobVrrm123
What was the problem?
06-10-2019, 09:19 PM
06-11-2019, 09:31 PM
I believe the SC boost is also factory-limited to 12 psi. The most I've seen on mine is 10.5 psi, at the Texas Mile.
06-12-2019, 04:08 PM
I've only got 9 psi but it's also 107 degrees right now is AZ and I had that could cause boost pressure loss.
Gary '09 C6
06-28-2019, 12:56 AM
I only see 7.5psi up here at 6000ft in an 8000ft DA ☹
06-28-2019, 08:40 AM
Thinking I am going to take mine down to the TX mile next year...
Gary '09 C6
I believe the SC boost is also factory-limited to 12 psi. The most I've seen on mine is 10.5 psi, at the Texas Mile .
06-28-2019, 11:16 AM
JacobVrrm123
Arizona heat lol.
I had Cordes do an edelbrock heat exchanger, their small under hood tank and the emp pump. It's going back in the second week of the month for a six gallon trunk tank and prospeed dual fan kit.
06-28-2019, 06:01 PM
St. Jude Donor '12-'13-'14
I usually see about 9 LBS at sea level
06-29-2019, 03:43 AM
There is a solution to this problem:
https://kongperformance.com/
