AC fan run high only on Recirc, help please
I recently purchased a 2009 Z06. I have noticed that the AC fan runs on high when the system is set to recirculate. If I turn off teh recirc, the fan slows down but not to a normal low speed. What could be the problem. This is my third c6 z06. None of the other cars did this. Do I have an ac fan control issue or something else like the BCM going bad. Everything else seems to work as it should.
Roger
Roger
The fan speed picks up a tad when Going to recirculating on all Gm cars then it slows down when taking it out of recirculate.
Any codes? Also, that doesn't sound wrong to me.
thing knower
i think its just a difference in sound from when the flap changes from outside to recirc...
also there is an air filter restricting air flow from the outside.... i don't believe there's a recirc air filter...
