C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
ZR-1 clutch in a Z06
Old 05-22-2019, 10:24 PM
jimbob8915
jimbob8915's Avatar
Default ZR-1 clutch in a Z06
So what parts do I need to mount a ZR-1 Clutch in my 06 Z. I currently have a Monster Lt-1 an it is very noisy. At my horsepower levels 540 rwhp a ZR-1 clutch do be quieter an OK for my needs.
Old 05-22-2019, 10:32 PM
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
What you have is better that the LS9X clutch kits...and much cheaper,
Old 05-23-2019, 12:03 AM
SLOWEST Z
SLOWEST Z's Avatar
I don’t have experience with monster clutch lt1-s, but I read good compliments about it.
Old 05-23-2019, 11:35 AM
Unreal
Unreal's Avatar
Received 2,314 Likes on 1,793 Posts
Zr1 is a downgrade and no one should be using it since the newer c7 stuff is an upgrade.
Old 05-23-2019, 09:37 PM
jimbob8915
jimbob8915's Avatar
What C7 options work with an 06 Z?
Old 05-23-2019, 09:45 PM
ttx350z
ttx350z's Avatar
Monster LT1-S. I’d buy it again when it’s time for a replacement.
Mine is dead silent. What noise does yours make?
Old 05-23-2019, 10:04 PM
VetteVinnie
VetteVinnie's Avatar
Received 1,764 Likes on 1,120 Posts
I had a Katech LS9X in my ~630rwhp Z06 with good results. I had a carbon twin disk in it, but I didn't like how it drove at all (too noisy). The organic clutch didn't track as nicely (slight delay to disengage), but for the street it was fine.
Old 05-24-2019, 11:15 AM
Unreal
Unreal's Avatar
The LT1-s is a c7 clutch. Which is a newer/better design of the OEM dual disk setups, and the ls9 is has a worse design and isn't nearly as good.
If it is making noise, you have an issue to fix.
Old 05-24-2019, 03:39 PM
VetteVinnie
C7 didn't exist yet when I had my 2008 Z06. Good to know about the LT1 clutch. But I wouldn't say a twin disk from a C6 ZR1 is a "downgrade" from the single disk in the LS7. It's still better than the single disk LS7 clutch. LS7 < LS9 < LT1.
My stock C6 ZR1 clutch is holding my 672rwhp just fine. If it ever goes out, I'll definitely look into the LT1/LT5 clutches.
Old 05-24-2019, 05:16 PM
Unreal
Unreal's Avatar
Not a downgrade compared to stock c6z but to what he has and a c7 clutch.
To ZR-1 clutch in a Z06
