new wheels on a z06
Say's the guy with factory HP levels....speak for yourself....or be clear....Traction is not a problem with 19/20's in the summer if your only making 450whp. like I said 19/20's wont hold much power.
I bet those off road tires ride an launch well. Nothing about tires for our cars is cheap. I run a set of factory replica 18x11's with 305/35's Mickey Thompson DR's that look kinda tall but nobody I know can not tell the difference between them an my 19x12's with the 325/30's
Man I’m not sure I’ve came across much of anything for our cars and thought....wow...that’s actually a reasonable price for what I’m getting lol....corvette problems
19/20 Swap, mine actually rides better then the stock wheels and tires. I had the original run flats. With this new setup I'm running continental extreme contact. They grip better then the stocks for sure but I'm putting close to 600hp to the wheels so kinda hard to get good grip. Thinking of doing some slip stream events so if I do I will swap out the rear rims and tires for something with traction.
I have 08Z06 went from 18/19s to 19/20s. PROs- After my alignment the handling in turns a lot better, traction much better even though you can still break them loose if you want. CON - cost per tire changed my driving ways ( lol), road bumps lot more noticeable. I love the 19/20 look fill up wheel well. Could not find my picture before so I just used a standard C6Z06 vs rim and size upgrade
Stock image 18/19
Upgrade 19/20
Stock image 18/19
Upgrade 19/20
#33
#37
