VETERANS. How do I ADD 100 HP to STOCK ZR1
I'm wanting to Add roughly 100 or so Hp to my bone stock ZR1.......
was thinking nitrous, but I would like to hear anyones opinions on what some of their first mods were..........
porting the blower, and stock snout........ or no porting and adding a LPE snout?
which pulley did you go with....
what were some of your first mods that made you love the car even more
I did a 2.6 and tune and that put me where I wanted to be.
Nitrous would be the easy most powerful single add on. You could do a 75-80 shot and that would yield 100+ at the motor
I do believe the LPE like kit with a 2.3 (instead of a 2.6) and gutted cats would get you very close if not right there.
Kong ported blower and snout + 102tb and Kong 5” intake with e85 and tune will get you where you want to be. Oh, and removing stock cats. Or skip the e85 and get a 2.3 upper (installed by Kong when he does the porting) with the tune. It really doesn’t take much
Moderator
Received 3,758 Likes
St. Jude Donor '18-'19-'20-'21-'22-'23
I would say if money is no object you could look into MAGNUSON SUPERCHARGER or possibly a procharger. Tons of hp, but also tons of $$
So using the stock snout really isn't worth putting the pulley on?
Would I have to get bigger injectors for the 2.3 pulley, or would the stock injectors be able to hold that....
I just want to be able to get into the mid to high 10s
Call Greg Kong of Kong Performance...…….
My car dyno'd at 525 RWHP Stock. With Headers (Pfadt Tri-Y), Tune, 2.6 upper & 14% lower pullies (Stock Snout & TB) it dyno'd 640 RWHP on pump 93, and 685 RWHP on E85. Then added NW102 TB, Ported Stock Snout & Blower (By Kong), retune went to 760 RWHP (E85), 720 (Pump 93).
Tether Man
Received 2,027 Likes
2019 C1 of Year Finalist (appearance mods)
704 RWHP 820+ to the Crank @ 6lbs boost (very conservative).........Methanol in the windshield washer reservoir LOL!!! Obviously not a ZR1.
Heintz Performance Racing Concord, NC (behind the Speedway)
You won’t need injectors with a 2.6, but if you go e85 you probably will max them out.
stock snout can be ported to 102, intakes are limited though but the synergy has worked for people for a while. Or get the Kong 5” and a custom made adapter.
So how much boost were you at with a 2.6 and 14% lower?
My experience: https://www.corvetteforum.com/forums...0whp-gain.html
Drag results: https://www.corvetteforum.com/forums...lts-redux.html
Received 1,679 Likes
WOW!!! Very nice.....
