C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
07 z06 head swap
Old 03-09-2019, 03:22 PM
07Z06Gamecock
07Z06Gamecock's Avatar
Default 07 z06 head swap
When removing driver side head and power steering pump. Do you have to remove the abs module?
Old 03-09-2019, 03:33 PM
Innovate
Innovate's Avatar
Yes, 2 15mm bolts under the car behind the sway bar on the subframe.
I have heads FS if you need some.
Old 03-09-2019, 03:35 PM
subfloor@centurytrans
Supporting Vendor
subfloor@centurytrans's Avatar
2020 Corvette of the Year Finalist (track prepared)
C6 of Year Winner (track prepared) 2019
No, you do not.
Old 03-09-2019, 04:12 PM
Medicdiver
Medicdiver's Avatar
St. Jude Donor '13
How much and what heads
Old 03-09-2019, 04:28 PM
Innovate
Innovate's Avatar
PM'd.
Old 03-09-2019, 04:41 PM
ss2z06
ss2z06's Avatar
No, if you remove the abs module bracket it gives you some more room and flexibility.
Old 03-10-2019, 08:23 AM
99Hawk262
99Hawk262's Avatar
I did it this way; removed the bracket and slid the entire assembly forward. I also removed the PS pump although I've read where this isn't necessary. It wasn't difficult, and freed up some space, so in the end it was worth it.
Old 03-10-2019, 08:27 AM
07Z06Gamecock
Thanks everyone for the feed back
Old 03-10-2019, 08:29 AM
07Z06Gamecock
One other question that im seeing different answers on is reusing the crank bolt. Reuse or get a new one?
Old 03-10-2019, 09:20 AM
99Hawk262
99Hawk262's Avatar
Def get a new one...ARP makes one that’s not too pricey. I believe they are a TTY one-time use item. So ARP or factory new.
To 07 z06 head swap
Quick Reply: 07 z06 head swap
