C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
Surging z06
Old 11-08-2018, 08:42 PM
Zo6chip
Zo6chip's Avatar
Default Surging z06
I purchased a 2006 z06 with Texas speed heads and stage 3 cam. Kooks headers and off road x pipe. The car has been tuned three times and still has a surge under 2500 rpms. I keep hearing it’s all in the tune but I’m starting to think it’s the cam. Don’t understand why Texas speed sells a cam for the street that is not driver friendly. It should be listed for race only. I’m looking to switch for a BTR 3. These guys know how to make a street cam. I’m not a fan of Texas speed right now
Old 11-08-2018, 08:50 PM
NemeZ
NemeZ's Avatar
I don’t think it should surge that high. Maybe under 2k would be normal. Where are you located?
Old 11-08-2018, 08:54 PM
Zo6chip
Zo6chip's Avatar
Columbia sc
Old 11-08-2018, 09:07 PM
lamboworld
lamboworld's Avatar
Originally Posted by Zo6chip
Columbia sc
Bring your car to Stephen Shoaf at https://www.facebook.com/sslsxtuning/ in Concord, NC and he will get it to drive as good as possible. Probably about 2 hours from you.
Old 11-08-2018, 09:15 PM
RedZ4me
RedZ4me's Avatar
Are you considering a switch based on brand? You need to understand specs before deciding and certaining do not overcam. Based on specs, you should consider the btr2, not the 3
Old 11-08-2018, 09:26 PM
Zo6chip
Zo6chip's Avatar
I will contact them tomorrow
Old 11-08-2018, 09:27 PM
Zo6chip
Zo6chip's Avatar
I have driven a z with the BTR 3 and it was smooth as stock
Old 11-09-2018, 10:32 AM
BigVette427
BigVette427's Avatar
Nothing wrong with the cam, TSP can custom grind a top-quality camshaft to nearly whatever duration and lobe slope angle that you want, on one of two different lobes for the 1.8 rocker arms on the LS7. Not sure if you cam may be Gen 1 or 2, but for the 2nd gen LS7 stage 3 cam, they say right on their website that the power band is 2800-6900 rpm. With 240/252 on a 111 LSA, that's 24° of overlap - you're only going to be able tune that to a certain degree. Unnecessairly obtrusive cams like these and aftermarket long-tube headers lower the value of the vehicle, IMO.
Old 11-09-2018, 11:49 AM
MickVette
MickVette's Avatar
St. Jude Donor '13
I put those cam specs on the DeskTop Dyno to see how it compared to other cams I have been looking at. It looks like it puts down nice power, has 18° of overlap and duration favoring the intake side compared to other LS7 cams I've looked at so I'm not sure how that works out on the tuning end of things.
Old 11-09-2018, 01:28 PM
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
Surging as high as 2500 rpm would suggest, at least to me, that its either a tuning issue, or something else mechanically isn't quite right. Out of curiosity, what CAI are you running?
Old 11-09-2018, 01:59 PM
lamboworld
lamboworld's Avatar
I am running a 22 degree overlap that Stephen tuned and it drives fantastic. However, there are a few mods that I have done that I believe help the drivability. I am running a different 5th and 6th gear which causes the rpms to run a tad higher, E85 also helps and 2" headers may also impact how it drives. Of course in parking lots it bucks and surges like any big cam, but it will cruise in 6th gear at 60mph with no surging or bucking.
Old 11-09-2018, 04:28 PM
silverboost98
silverboost98's Avatar
I was having the same issue with a BTR stage III cam where I was getting lots of surging. I got a re-tune done by PCM of NC and they solved all my driveability issues. Sucks that I had to spend another $500+, but it was so worth it and makes the car so much more fun to drive. Power also is more linear than before as well.
If you don't mind private message me to whom your tuner is currently. On another note it took me nearly 4 months to get an appointment with PCM of NC as they are so damn busy.
Old 11-09-2018, 04:58 PM
BigVette427
Patrick Guerra will work with you remotely; you won't find a better tuner.
https://www.guerragroup.com/efi-tuning
Old 11-10-2018, 12:50 PM
Zo6chip
Zo6chip's Avatar
live been talking with Stephen for the last couple days. Trying to get a copy of my tune for him to review. He’s not sure if he can get it any better but he is willing to take a look at the tune. Maybe can just make a few adjustment to the low speed section and won’t require Dyno time. He is booked up until mid January on the Dyno. At least he’s not saying he can fix it like some.
Old 11-10-2018, 09:45 PM
Apocolipse
Apocolipse's Avatar
Received 1,290 Likes on 934 Posts
More than likely need to smooth the timing around the cruise area and either add or remove timing based on what your car wants. Mine responded well to near stock timing where other people take 15deg out to load the motor up.
Old 01-27-2019, 01:58 PM
Zo6chip
Zo6chip's Avatar
The latest update on the surging. I had another guy do a road tune instead of the Dyno. Was suppose to help with drivability. Still no difference. I have an appointment with Steven mid March for a cam change. Going with the BTR2. I’ve been running down suggestions for the cause like vacuum leaks. I have 11” of vacuum at 1000 rpms cold. Seems low but it might be normal with a big cam. If it was spark I’m sure it would cause a code. Any other suggestion before I spend the money for a cam change. Thanks for your help.
Old 01-27-2019, 03:31 PM
Sox-Fan
Sox-Fan's Avatar
What do you have for an air intake, and has the radiator shroud been cut open to "let more air in?"
To Surging z06
Old 01-27-2019, 04:50 PM
Zo6chip
Zo6chip's Avatar
Corsa cold air intake and I think the radiator shroud is stock.
Old 01-27-2019, 07:44 PM
Sox-Fan
Sox-Fan's Avatar
Almost positive the issues you're having is not enough or turbulent airflow over the MAF. I'd try a different air filter setup as a quick test, or if you have a honeycomb straightener try putting it in front of the MAF to smooth the airflow and see if the MAF likes that better. If you search for surging here you'll find that a lot of itmes that is caused by cutting the radiator shroud, but it can also be the shape of the air housing and MAF location. There really is no straight line for air to to get headed in a straight shot before the MAF on that intake.
https://www.corvetteforum.com/forums...ake-box-2.html
Old 01-27-2019, 08:20 PM
Zo6chip
Zo6chip's Avatar
What if I just remove the filter for a test.
Quick Reply: Surging z06
