LS7 titanium rod failure
#41
The coating is going to wear off at some point in time regardless if you run the very best oil available......it's just a matter of when. Those of us who have significant power enhancements put additional stresses on that rotating assembly, then add how often you exercise the engine in the upper RPM ranges, and that just accelerates the wear. Just like the guide issue, it pays to keep an eye on it and routine oil analysis can give you a heads up on potential rod issues before it becomes catastrophic.
18JamesS (08-28-2021)
#42
Victor, putting this out there, since you didn't mention it (intentionally, I assume).
From your description of events, one could ask "what part did the new components (swapping rod bolts, etc.) and the machining and setup work done by the shop play in this failure?".
I realise that we've witnessed plenty of failures of this type on un-touched bottom ends, but it's the elephant in the room..
#43
09 z06 oil analysis
I've also heard that Ti retainers installed during the "Head Fix" could be a likely source of lower levels of Ti. I seen someone on the forum mention somewhere. Just can't remember. Anyone else heard that?
#45
I do have the Ti rods for sale, would expect they would need to be coated. I have to figure out how to remove the wrist pin retainers, though unless someone wanted the pistons, too.
#47
Received 1,679 Likes
Vic, did you see, hear any symptoms that this was going on? Or was it simply a pre maint ( pro active) thing. That is pretty scary actually.... Think i'll do the Blackstone thing next time I change the oil... If nothing else I will have piece of mind.
#48
Jumping in a bit late...but for $5K there are much cheaper alternatives that are a "better value" than titanium stockers. For instance, you can get a completely custom set (as in measured and made for you specifically) of billet rods for about $3K. And you can buy some Callies Ultra rods for about $2K a set. Both options will handle all the power you can throw at them and you're not really sacrificing that much weight. It's not going to be noticeable when driving the car, I can assure you.
GoJuice505 (07-28-2020)
#49
Yep, I heard a sound that reminded me of when my torque tube couplers went out !!! It came at the end of a drag race pass as I decelerated; I immediately checked all of my gauges and noted oil pressure was still in the mid 50's so I did not immediately identify it as being a bearing issue. I got the car into the pits, noted that oil pressure was still good, and shut it down. I had the car trailered home and it wasn't until a I dropped the oil did I find all of the gold flakes in the oil and significant metal content sticking to the magnetic oil drain plug.
#50
I also agree with you that there are "better value" alternatives out there, that owners who plan on significantly modding their cars should look into. I don't know if there's been anyone who's had the titanium rods re-treated with an anti-friction coating that has then put any significant amount of miles on them...would be a good option if any credible data could be amassed on this option.
Until then, monitor your oil changes for significant jumps in titanium content, which should give you enough time to plan your rebuild and salvage as much of the OEM motor as you can.
#52
The following 2 users liked this post by Unreal:
MikeOC (09-24-2019),
SteveDoten (09-22-2019)
James Dean (09-25-2019)
MikeOC (09-24-2019)
#55
I think it was the 2009 model year engine that got the updated rods, along with the increase oil capacity sump tank.
MikeOC (09-24-2019)
#56
Good info. A lot of changes in ‘09 so that was my first guess but I’ve got ‘08 rods and I’m hoping they have them. I’ll probably end up using piston squirters so it’s probably not critical but it would be nice to know.
#57
Either way, oil channel or not, they fail so isn't a big difference.
#58
#60
