C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
Wrong differential fluid in c6 z06
Old 05-24-2018, 06:19 AM
Daniel94B
Daniel94B's Avatar
Default Wrong differential fluid in c6 z06
Hi guys,
The dealership here has given me wrong differential fluid, the car started to make bad noise in tight corners and roundabouts.
I havent used the car much at all since. What im wondering is if this will cause my differential to have permanent damage? Or should a oil change with the right fluid fix it?
Old 05-24-2018, 07:21 AM
itomh
itomh's Avatar
I would change fluid immediately, run it for a couple of cycles and change it again.
Daniel94B (05-26-2018)
Old 05-24-2018, 07:43 AM
C6Z06Silverbullet
C6Z06Silverbullet's Avatar
Originally Posted by Daniel94B
Hi guys,
Sounds liked the fluid wasnt for a posi rear. I also suggest changing the fluid now! Then again after that.
Old 05-24-2018, 07:57 AM
Daniel94B
Daniel94B's Avatar
The fluid is a 75w-90 without LS lubrication, and the idiot didnt give me a additive with it.
If they wont take responsibility i will just get new and RIGHT oil and change it.
I just hope this short term usage havent torn anything
Old 05-24-2018, 07:58 AM
C6Z06Silverbullet
How long have you been driving it that way?
Old 05-24-2018, 08:01 AM
Apocolipse
Apocolipse's Avatar
Received 1,290 Likes on 934 Posts
Dont worry about it.
get it on a hoist and toss in a bottle of slip additive. Done.
Old 05-24-2018, 08:11 AM
Daniel94B
Daniel94B's Avatar
Drove it that way approx 10-20 km approx. And everything is fine when driving straight just corners are bad.
Daniel94B
Daniel94B's Avatar
I actually did that it got much better but i can still hear it clearly
Old 05-24-2018, 08:12 AM
C6Z06Silverbullet
In that case I agree just dump a bottle of additive in. You will be fine.
Apocolipse
Apocolipse's Avatar
Its fine.
if you added it go to a parking lot and start doing figure 8's to get the fluid to the packs.
Also helps if the oil is hot when doing this after a nice long highway cruise.
Old 05-24-2018, 08:14 AM
C6Z06Silverbullet
Change the fluid then. Get the Mobil one with additive in it already or the royal purple .
Old 05-24-2018, 10:26 AM
ssbowtie1
ssbowtie1's Avatar
Did he give you the GM fluid? That comes with additive already in it.
Old 05-24-2018, 10:30 AM
C6Z06Silverbullet
Its fine.
Old 05-24-2018, 02:08 PM
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
Yeah, I'm confused...OP said "dealership", so I would think its GM fluid. More to the story maybe...
Old 05-24-2018, 03:14 PM
racebum
racebum's Avatar
if it's chattering you just have the no additive fluid. as suggested above. just add the additive and do a bunch of figure 8s.
very easy to remedy
Old 05-24-2018, 04:44 PM
BigVette427
BigVette427's Avatar
Sounds fine. Figure eights to get the fluid out to all the clutch plates and then check fluid level and top off if necessary.
https://www.corvetteforum.com/forums...-specific.html
Old 05-24-2018, 09:33 PM
ssbowtie1
ssbowtie1's Avatar
My dealer also offers M1 diff fluid, so maybe they sold him that without the additive?
Personally I stick with factory fill for the trans and the diff...
To Wrong differential fluid in c6 z06
Old 05-25-2018, 03:36 AM
Daniel94B
Daniel94B's Avatar
Thanks for all the replies guys. Well i live in Sweden and the GM oil isint allowed by europe standards. So they gave me something that isint OEM.
I have talked with our Corvette specialist in Stockholm and he recommended Motul LS gl5 75w-90 and said that it works fine and that they always have used it.
My biggest concern is if my differential took damage during the short time without additive modifier
Old 05-25-2018, 03:43 AM
Daniel94B
Daniel94B's Avatar
A bottle of modifier that many of you have suggested has reduced the noise alot but it is still there. Ive done figure eights and drove in circles etc but the shattering noise havent ceased totally
Old 05-25-2018, 05:39 AM
sccaGT1racer
sccaGT1racer's Avatar
just get the additive in it and drive it. The short time you drove it did no damage. Its just a drain and fill so the plates had lube on them just not enough friction modifier. Go do some figure 8's to get the fluid worked in.
Quick Reply: Wrong differential fluid in c6 z06
