C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Against the grain
Old 10-15-2018, 05:32 PM
  #421
jayyyw
jayyyw's Avatar
Originally Posted by 0H8Z06
You dealing with Anthony or Eric? They are about 20 min from my house... Do I need to go bang some heads for ya!? lol
Shoot, if you can get the price knocked down a bit that would be great! LOL. I believe Anthony sent me the quote.
Old 10-15-2018, 05:45 PM
  #422
TXGS507
TXGS507's Avatar
Received 1,679 Likes on 1,135 Posts
No promises but Anthony is a good friend of mine.. I'll try and zig by their shop this week.
jayyyw (10-15-2018)
Old 10-15-2018, 06:04 PM
  #423
jayyyw
jayyyw's Avatar
Old 10-15-2018, 06:20 PM
  #424
FNBADAZ06
FNBADAZ06's Avatar
You'll probably see my block there
TXGS507 (10-16-2018)
Old 10-16-2018, 11:38 AM
  #425
jayyyw
jayyyw's Avatar
Going to try to swing by the facility early November. I'll be in the area.
Old 10-16-2018, 04:25 PM
  #426
jayyyw
jayyyw's Avatar
99% going with HPR. Anthony has answered every question I've had so far.
Just need to sell my short block now.
Old 10-16-2018, 08:44 PM
  #427
Turbo2L
Turbo2L's Avatar
How many cubes?
Old 10-16-2018, 09:58 PM
  #428
TXGS507
TXGS507's Avatar
How early in Nov? I'll be in Phoenix (Military Conf) from 2-5.... PM me a couple of days prior and we can grab some lunch. I'll meet you over there.
Old 10-16-2018, 10:00 PM
  #429
TXGS507
TXGS507's Avatar
Anthony is good people... He and I go back to the LG days... He is also a pretty talented tuner....
Old 10-17-2018, 08:35 AM
  #430
jayyyw
jayyyw's Avatar
Originally Posted by Turbo2L
How many cubes?
Staying 427ci but should be right around 13:1 compression, nice sized cam (25X/26X .666/.666 111+4), still 1-7/8" headers (for now), vac pump, electric water pump, LME heads milled another .010'-.020" to acheive the 13:1. Should flirt with the 700whp mark on e85.
Debating on going to a direct port or the NX plenum spacer for the hi ram. Bonus of the plenum spacer is more plenum volume, which should help on spray. I don't plan on spray anything more than a 250shot. That should make mid 900s whp.
Actually, those are the days I'll be there. :[ Going up with my wife to explore Dallas with the City Pass. Friday and Saturday I believe. I'll hit you up anyway just in case you are still in town. I'd venture to say HPR would be one of our first stops in the AM.
Yes, you are right about that. Very knowledgeable. Learned a lot from our few e-mail exchanges.
Old 10-17-2018, 02:41 PM
  #431
~STOLEN~
~STOLEN~'s Avatar
DO THE SPACER IN THE HI RAM !!!!!!
that would be SICK!!!
jayyyw (10-17-2018)
Old 10-17-2018, 04:27 PM
  #432
Millenium Z06
Moderator
Millenium Z06's Avatar
400 Shot or sale the car
Old 10-17-2018, 04:34 PM
  #433
jayyyw
jayyyw's Avatar
Well.... I guess it's for sale then.. LOL
Old 10-17-2018, 04:49 PM
  #434
Innovate
Innovate's Avatar
Da Z06 needs your shortblock!
Anyway, HPR is definitely the route to go. I know I would probably go HPR 468 if I swapped bottom ends (depending on timing and price). That and I would go direct port, not a nitrous guru by no means though. The plenum spacer may be better.
Old 10-17-2018, 05:21 PM
  #435
jayyyw
jayyyw's Avatar
I've already spoke with him. I believe he is going a different route.
The 468ci is cool and all, and if I was going to stay strictly N/A, it's a no brainer. Unfortunately, in order to achieve that CI, they use a small, custom piston. Not ideal for power adders. I'll be knocking on the door of 4 digits when I really put it down. It should move out pretty well. If I'm feeling really froggy, I'll throw in a 350 jet and let it eat.
I may even continue to run the dry shot through the spacer plate. I can do a 2 stage that way. The possibilities are endless!
Old 10-17-2018, 05:29 PM
  #436
Innovate
Innovate's Avatar
I got you, I saw him list the car FS on FB.
Makes sense, definitely interested to see what is next. 350 on your car will be crazy, especially since you may already make more power with the HPR motor.
Old 10-17-2018, 05:38 PM
  #437
jayyyw
jayyyw's Avatar
I didn't see that he listed it for sale! Woah.
Yeah, I'm hoping to make a little more with the added compression and larger camshaft.
To Against the grain
Old 10-18-2018, 11:00 AM
  #438
Millenium Z06
Moderator
Stroke on a 468 might not be good for a power adder either, depends on how long the sleeves are and even then, you're dealing with rod angles and side loading at the bottom of the bore/stroke
jayyyw (10-21-2018)
Old 10-21-2018, 09:44 AM
  #439
jayyyw
jayyyw's Avatar
So, if you haven't noticed lately, I am VERY indecisive. I think I am going to stay with the stock bottom end for a little longer and follow through with my original plans to tear it down mid next year.
That being said, I am currently looking for 2" ARH headers and an electric water pump. Will also be installing a plate kit on my hi ram and going to a wet shot instead of a dry shot.
I am waiting on a quote for the following, from my tuner:
8620 core camshaft DA Z06 custom specs
Johnson 2116 short travel lifters
LS9 oil pump and drive gear
Plus OEM head gaskets, water pump gasket, timing cover gasket, etc...
Going to have my heads milled for 62cc. Roughly 2.5cc more.
Old 10-21-2018, 09:52 AM
  #440
lamboworld
lamboworld's Avatar
I still have my Stand Alone tank and pump available if you are interested. I strictly used C16 in the tank and I was basically able to run any size shot that I wanted to. I ran up to a 250 shot, but I am sure that you could run much bigger since you are not depending on your injectors providing fuel.
Quick Reply: [Z06] Against the grain
