[Z06] Shortblock
Shortblock
So I pulled the trigger on a ls7 shortblock with forged diamond ultra lite pistons arp rod and main bolts . Think it’s at 11.5 compression with my heads being .030 milled. What gap
should I go on the pistons for boost/nos/NA? Is there a ideal safe gap for all?
It depends on the piston and how far down the ring land is, also how much extra power do you think you want to add. Talk to your engine builder and figure that out.
a incredible garage with like 5 ls7s all Done up short or long blocks with 4-5 sets of heads. He told me the weakest part is the connecting rods. And how much of a difference will lighter pistons make only by like 6 grams each I think
I know that this is a moot point for you now, but you should have bought a Darton Sleeved 5.3 block from Texas Speed for about 2 grand and sold your LS7 block for about the same price. You can then then go up to a 250 shot from a plate setup without much worry as long as you are running a stand alone fuel tank with your nitrous setup. I would not attempt to run a 175 shot off of the fuel rail.
I would do a smaller shot since it seems that block is not sleeved and has stock crank/rods. Correct? Compression is too high for boost even on e85. It can be done but reliably I don’t think so.
I would do no nitrous...because I wouldn’t want to be on my 3rd motor. Just me...I’ve always said, “all throttle, no bottle”. If I want more...I go FI.
I would have done .024” on the top ring(no boost). Too much is way better than too little when it comes to end gaps.
i mean for 5400$ shipped shortblock with stock
block crank and rods with diamond pistons and arp
stuff I couldn’t find anything cheaper pre built
go through this again. I might just sell my short block again smh. But if I can get high miles NA at 600whp I’ll just stay NA and down the road I guess a year or two sell the shortblock and build something crazy a TT 427
You go from talking about longevity to talking about adding spray and boost on stock liners, which is it?
You don't want to do this again? Coulda fooled me.
If you don't want to do anything again, and want it to last, and you want to use your parts you have, here is what I would suggest.
N/A for now, you can even put a boost cam in now if you really want to save money later.
If you go full time E85 you can add boost just fine later with your SCR, but go no higher than 6 psi/700 wheel with a turbo, and don't spray on top of that. Should last like that.
Just my opinion, and it's worth what you paid for it.
