C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[ZR1] What clutch fluid to use
Old 01-23-2018, 07:02 AM
simnova6
simnova6's Avatar
Default What clutch fluid to use
hey guys I'm planning on doing some early maintenance on my slave cylinder to prolong its life. Just curious what would be the best clutch fluid to use thanks for any input
Old 01-23-2018, 08:56 AM
MacofTampa
MacofTampa's Avatar
Castrol SRF, its expensive so it must be good! It has very high boiling temp ratings and is comparable with both DOT 3 & 4 brake fluids specifications...Mac
Old 01-23-2018, 09:07 AM
TXGS507
TXGS507's Avatar
Received 1,679 Likes on 1,135 Posts
Running the Motul....
Old 01-23-2018, 09:14 AM
Schred86
Schred86's Avatar
Amsoil dot4
Old 01-23-2018, 10:24 AM
Tech
Tech's Avatar
Wilwood EXP 600 Plus
Old 01-23-2018, 11:47 AM
Larry Myers
Larry Myers's Avatar
The only thing important when servicing clutch fluid is that it's DOT4.
The brand is not important when used in the clutch hydraulic system.
Some time back GM issued a bulletin advising that because of numerous clutch master cylinder failures it would provide an improved version. This guidance was applicable to certain model year vehicles.
The replacement component can be identified by a black reservoir and DOT4 on the reservoir cap.
Several lengthy threads covering this issue on this forum.
I understand you didn't ask about the clutch master cylinder but thought it might be helpful to ensure the health of your hydraulic system.
Old 01-23-2018, 01:09 PM
Tech
Tech's Avatar
I agree with this for a stock vehicle but the Wilwood EXP 600 Plus fluid I suggested helped me when I had a high RPM shifting issue. My car was modified including aftermarket exhaust (more heat transferring to clutch line) and clutch (throw could be different based upon diaphragm spring).
Old 01-23-2018, 03:00 PM
TXGS507
TXGS507's Avatar
I too am experiencing this... high RPM from 3rd to 4th the clutch acts "lazy" for lack of a better term. It doesn't slip, smell, or stick to the floor.. But it does act lazy @ those higher RPM shifts.
Someone told me I should insulate the MC cable due to the heat from the long tubes. they also suggested to change to Motul... Which I did. I still experience it from time to time. Mine is the OEM Master from the factory.
Old 01-23-2018, 03:34 PM
Mordeth
Mordeth's Avatar
Received 1,678 Likes on 878 Posts
2018 C6 of Year Finalist
St. Jude Donor '10, '17
Motul 600 here for the clutch. For street/garage queen Prestone DOT 4 also works perfectly fine.
NotreOkc (06-14-2021)
Old 01-23-2018, 09:28 PM
simnova6
simnova6's Avatar
Wow. Everybody uses a different one lol. Interesting
Old 01-23-2018, 09:38 PM
Gary '09 C6
Support Corvetteforum!
Gary '09 C6's Avatar
I use Prestone DOT 4 in both the clutch and brake systems.
Car is not regularly tracked, except at the Texas Mile (2012--2016). I plan to return to the Mile later this year.
Old 01-23-2018, 11:19 PM
BearZ06
BearZ06's Avatar
Received 1,374 Likes on 793 Posts
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'22-'23
Prestone DOT 4 here too.
Old 01-24-2018, 03:37 AM
REDZED2
REDZED2's Avatar
Old 01-24-2018, 09:37 AM
TXGS507
TXGS507's Avatar
What do you agree with Derek?
Originally Posted by wantbluC6
Old 01-24-2018, 09:47 AM
BAAD LS2
BAAD LS2's Avatar
2018 Corvette of the Year Finalist
2017 C6 of Year
SRF is the best.
phils C5 vette (04-07-2018)
Old 01-26-2018, 10:36 AM
rabrooks
rabrooks's Avatar
Originally Posted by BAAD LS2
SRF is the best.
SRF is crazy overkill. Who needs 600 degree boiling point in a clutch system. And at $75 per quart. ouch
Any good DOT 4 is all the clutch system needs (Penzoil)
I have SRF in the brake system but only cause its a track car
Old 01-26-2018, 10:49 AM
MacofTampa
MacofTampa's Avatar
OP asked for the "best"
To What clutch fluid to use
Old 01-26-2018, 11:19 AM
Tech
Tech's Avatar
KAdams29 (04-07-2021)
Old 01-26-2018, 11:41 AM
Larry Myers
I agree.
Clutch hydraulics operate at a much lower temperature than brakes. Therefore, in my experience, exotic fluid is not required.
In my clutch I use AC Delco fluid. Only because the Vette tech. at the dealer gave me several cans. In the 13 years I've driven the car the clutch has been flawless. This includes about 65,000 street/track miles and 50/60 track days.
Good clutch maintenance involves using DOT4 fluid, keeping said fluid clean and installing the improved master cylinder.
Brakes, of course, a completely different matter.
The bottom line is if one gets a warm fuzzy using hi. temp. fluid in their clutch, go for it. Just one of the choices we make as with tires, engine oil, brake pads, ect.
Old 01-26-2018, 07:09 PM
REDZED2
REDZED2's Avatar
HAHA Matt
Dat Prestooooone DawT fior. GREET 4 my moter tuuu.
Quick Reply: [ZR1] What clutch fluid to use
