C6 Corvette ZR1 & Z06General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
You will need to scan it for codes. Without the codes you will waste time and money.
This is correct. I had a service traction control, active handling and ABS warning all due to a dead spark plug. I took it straight to Chevy without reading the codes and spent $350 in diagnostics and a new spark plug!
Could have just read the code and tried a new plug for a few bucks and would have solved everything.
