C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Heads and Cam C6Z oil question
Old 05-17-2017, 12:00 AM
madman91
madman91's Avatar
Default Heads and Cam C6Z oil question
Hello everyone, please don't flame me too bad for this question. Here goes.
I bought a 2008 C6Z that has heads/cam/longtubes and when speaking with a local big name LS tuner, they said i should only run Valvoline 10w40 CONVENTIONAL oil in the car or i could risk lifter failure (they did the cam and tune).
However when speaking with the previous owner, he said he started out running what the tuner told him but then switched to Mobil 1 5w20 Synthetic.
I don't want any issues so i'd really like some advice on what to run.
Thanks!
Old 05-17-2017, 12:45 AM
SpnkbnkZ06
SpnkbnkZ06's Avatar
Any oil that has a high ZDDP content will be effective
Old 05-17-2017, 01:28 AM
AzDave47
Support Corvetteforum!
AzDave47's Avatar
Received 4,580 Likes on 2,642 Posts
M1 0W-40, Amsoil Z-rod 10W30 or other quality synthetics will work fine. If you don't track your car or the oil doesn't get above 260*, then M1 5W-30 would be OK, but not my first choice over the others listed above. I think the M1 5W-30 high mileage oil has more ZDDP than the Dexos M1 5W-30.
Old 05-17-2017, 01:30 AM
bd4airman11
bd4airman11's Avatar
Thanks!
I would find a different tuner...oil like that can not get thin enough to speed through the coolers and then to the tank....and yes 100% synthetic with a high ZDDP....
Old 05-17-2017, 02:44 AM
MTPZ06
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
M1 0w-40
Old 05-17-2017, 09:13 AM
Schred86
Schred86's Avatar
Amsoil z rod 10w-30 or amsoil signature series 5w-30. The zrod has more zinc so thats what i run.
Old 05-17-2017, 09:26 AM
psp6158
psp6158's Avatar
Joe Gibbs LS. If you want to catch up on oil, google, Bob is the oil guy, been in the industry for a long time, independent studies, his own forum etc etc. My builder suggested Gibbs and it is near the top of Bob's testing.
Old 05-17-2017, 09:28 AM
Michael_D
Michael_D's Avatar
Thanks!
That's some of the dumbest **** I've seen on the board in a while........
Use a good quality synthetic oil, and a good filter. Don't go heavier than 40 weight, unless the car is a dedicated road/track car and you allow the oil to reach temp prior to hammering on it. Don't use 20 weight. Use either 30 or 40 weight, multi-viscosity.
All you need to do is search "which oil" on this site to find hundreds of threads, same tone, same BS, and even the same guys preached that zinc will save the world.... Everyone has a favorite.
Old 05-17-2017, 10:01 AM
Must_Have_Z
Must_Have_Z's Avatar
Please read this thread, especially post #1. Bottom line, stick with the 5W-30. (I have full cam and all the bolt-on's and I never once thought about switching oils.)
https://www.corvetteforum.com/forums...0-vs-0w40.html
Old 05-17-2017, 10:52 AM
Unreal
Unreal's Avatar
Received 2,314 Likes on 1,793 Posts
Besides break in, I've run Zrod 10-30 and currently have m1 0-40 in the car because I needed oil quick and that is what walmart had.
Any good synthetic should work. Amsoil, Redline, Brad Penn, Gibbs, etc etc.
Just picked up more zrod yesterday, to get this M1 0-40 out this weekend. It worked ok, but I prefer the zrod.
Old 05-17-2017, 11:24 AM
spy2520
spy2520's Avatar
I wonder if that tuner was talking about valvoline VR1 oil. It has high ZDDP if i recall correctly.
Old 05-17-2017, 03:40 PM
madman91
madman91's Avatar
I agree! I did not like hearing that at all. Especially from a big name tuner that's a vendor on here.
Old 05-17-2017, 03:42 PM
madman91
madman91's Avatar
I had him confirm 3 times. Plain Valvoline.
Old 05-17-2017, 03:55 PM
pokerpro
pokerpro's Avatar
2021 C6 of the Year Finalist - Modified
2020 C6 of the Year Finalist - Modified
2015 C6 of Year Finalist
If he is in deed a vendor here why is it taboo for you to say who it is?
Old 05-17-2017, 04:17 PM
madman91
madman91's Avatar
I'd rather not drag their name through the mud. Its possible that they misspoke or something like that.
Old 05-17-2017, 05:48 PM
spy2520
spy2520's Avatar
Definitely weird. VR1 does come in conventional and synthetic. And the conventional has more ZDDP. I dunno about plain jane valvoline though.
Old 05-18-2017, 10:34 AM
Michael_D
Michael_D's Avatar
Only time I worry about whether or not to use straight dyno oil, is for a fresh engine break in.....IE: ring seat. Syn vrs dyno has absolutely nothing to do with lifter performance. Viscosity does.
Big name vendor/tuner doesn't mean anything to me. I am continually disgusted by the crap so-called tuners do.
To Heads and Cam C6Z oil question
Old 05-18-2017, 10:35 AM
Must_Have_Z
I wish vendors/shops would say why NOT to use Mobil 1 5W-30 that GM recommends vs. just saying "You should only use XXX brand oil."
If someone can't give me a good reason to NOT use GM's recommendation, I'll keep using it.
Old 05-18-2017, 04:25 PM
LMB-Z
LMB-Z's Avatar
I have heads, cam, CAI, and tune. Not big numbers but 525 rwhp. The shop that did my build told me to run Motul. First time I changed my oil, I put Mobile 1 5w-30 back in. Almost 20k miles later and not a problem of any kind, no leaks, no noise, no oil consumption, nothing.
I do not track my car at all. Just occasional spirited driving.
Old 05-18-2017, 09:41 PM
madman91
madman91's Avatar
So just to confirm, i should be fine using good ol Mobil 1 5W30 and an AC Delco filter?
Quick Reply: [Z06] Heads and Cam C6Z oil question
