C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Different Brands of Wheel Bearings and Quality
Old 05-09-2017, 01:09 PM
no cigar
no cigar's Avatar
Default Different Brands of Wheel Bearings and Quality
Greetings guys... I have diagnosed what seems to be a bad rear wheel bearing/spindle on my 07 Z.
I know the idea is to always stick with Delco/OEM units, however in searching I have found Centric and Moog both make a unit for our cars.
I used Centric components on my previous Cobra in the past and was happy with their parts. Moog is also a fairly established Mfr as well. I have all Moog parts to rebuild the front end on my daily and hands down looks like top notch quality.
The parts I've found are:
Centric 402.62026E:https://www.summitracing.com/parts/c...model/corvette
Moog 512442:
Amazon Amazon
Any thoughts? Thanks!
Old 05-09-2017, 02:12 PM
carefulnow
carefulnow's Avatar
Skf?
Old 05-09-2017, 02:29 PM
no cigar
no cigar's Avatar
The only SKF unit I've been able to find is a competition/race unit that is close to $400 each. That would be out of my price range.
I should say that I'm considering the Centric/Moog units as they are cheaper than OEM.
Old 05-09-2017, 02:43 PM
96GS#007
96GS#007's Avatar
Received 1,779 Likes on 1,069 Posts
Street only car, I'd use Moog and you'll never know the difference from OEM. If you plan to auto-x or do track days, then SKF.
Old 05-09-2017, 02:56 PM
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
Moog has a solid reputation...probably what I'd go with in your shoes.
Old 05-09-2017, 03:37 PM
atljar
atljar's Avatar
SKF rears are available at rockauto.com for $120. Part# BR930198
The following 2 users liked this post by atljar:
63Corvette (06-08-2017), no cigar (05-09-2017)
Old 05-09-2017, 06:07 PM
no cigar
no cigar's Avatar
Thank you sir!
Old 06-08-2017, 05:10 PM
no cigar
no cigar's Avatar
Wasn't able to find these on rock auto but did find on ebay for $117 shipped. SKF units.
They work very nicely. Turns out the drivers side rear was shot but I replaced the pair. May consider doing the front as well at some point. The hardest part was breaking loose the lower ball joints.
Old 03-14-2019, 11:35 AM
no cigar
no cigar's Avatar
Just replaced the fronts with MOOG units. They seem to be working nicely!
Old 03-18-2019, 11:40 AM
JaredW
JaredW's Avatar
Did you notice a quality difference between the SKF and Moog units? I'm going to switch to C5 axles and figured I would replace my rear wheel bearings at the same time because I think I have a slight noise from the pass side.
Considering these 3, as they are all about the same price. The Timken's have the shortest warranty, no sure if that even matters.
Timken: https://www.rockauto.com/en/moreinfo...1433663&jsn=22
SKF: https://www.rockauto.com/en/moreinfo...1433663&jsn=27
Moog: https://www.rockauto.com/en/moreinfo...&jsn=26&jsn=26
Old 03-18-2019, 12:57 PM
no cigar
no cigar's Avatar
That I saw, there was no difference in quality. The only thing I didn't really like about the SKF's, if I remember correctly, was that the clips for the ABS sensors were not a good fit on their brackets. The MOOGs clipped right on. Minor headache but I'd go with the MOOG if I had to do it again.
I should also say that the SKFs are also rusting rather quickly.
JaredW (03-18-2019)
Old 03-18-2019, 02:04 PM
JaredW
JaredW's Avatar
Thanks! I appreciate the insight, RockAuto seemed to be the cheapest I could find them. Advanced Auto was $100 more each!
Old 03-20-2019, 01:30 PM
2k Cobra
2k Cobra's Avatar
Default Non Track use miles??
How many miles are you getting with non track use??
To Different Brands of Wheel Bearings and Quality
Quick Reply: [Z06] Different Brands of Wheel Bearings and Quality
