[Z06] Optima Ultimate Street Car NOLA
I might like to have a chat with you about the C.O. setup, valving, spring rates, mounting, etc. if you have time - I've used Penske's before in other applications with good results.
In your previous posts you said you "had brake issues".. Something up with that prototype setup? If you can't (or won't) say due to an NDA, that's fine.
Vents in the hood...did you double up on the Camaro vent that some guys are cutting/installing into the center hood section, or are those something else?
Yeah, I have to go check one out some day. Unless they plan come to Hawaii for one event...kind of like the Pro Bowl used to.
MTPZ06 (04-28-2017)
Premium Supporting Vendor
A perfect score for a weekend is 500, but the closest anyone has ever gotten is 494. Once points are distributed, cars are split into one of five classes, so even if someone in the GTV class for cars built before 1990, only has 389 points, if that's the most in his class that weekend, he gets an invitation to the 2017 SEMA Show and OPTIMA Ultimate Street Car Invitational.
Invitations are also awarded at the end of the season to the top-three non-qualifiers from each class and the next 10, regardless of class. There is also a regular season points championship in each class and the point totals from a competitor's best three events count toward their season total for both the championship and OUSCI qualification.
Here's a link to Super Chevy's coverage from New Orleans.
Jim McIlvaine
eCare Manager, OPTIMA Batteries
www.facebook.com/optimabatteries
