[Z06] Random hose in the rear battery compartment
I have talked to enough techs and others about this. I bet you there are thousands with the hose just dangling in the battery box. My buddies car and mine both have Johnson Controls GM factory batteries and no solid connection to the battery. His battery hasn't exploded. 8 years and still going. Lid shut. Blown out of proportion. JMO. There should be a GM plastic connector to mate the hose to the battery if one so chooses. Don't know part number.
..hey I have looked when I first bought my Z06 in 2015 and I have a hose but not hard 90 degree elbow connector to go in to the battery. Can't find the part online that fits (C6 Z06) if I wanted to get one even. The only Delco vent hose that shows up is for Cobalts ???
Not sure what that has to do with you basically advising the OP not to worry about it. If you don't want to hook yours up (for whatever reason), that's up to you. I just don't think you should be advising other people not to hook it up. To me, it's like saying you don't need to wear your seat belt because you've never needed it before.
I just checked my battery that is the standard Delco for the Z06 and the hose is hooked up directly to the battery. The battery was replaced at Abel Chevrolet about 2 years ago, so it all seems fairly standard as long as it is OEM.
The AutoZone Duralast Gold hoked right up to the vent also.
And what good did your response do? The OP never asked for anybody's opinion whether or not to hook it up, he only asked what the hose was for. You offered your unsolicited opinion about it being ok not to hook it up and it is my opinion that it is irresponsible to suggest bypassing a safety feature. If GM thought it vented enough then they wouldn't have included a vent hose. If you post something like that on a public forum you have to expect people who have a different opinion are going to respond. Sorry if you are so sensitive that you feel you have to throw insults at someone who has a different opinion than yours (and evidently I wasn't the only one who didn't think your response was appropriate). This will be my last response about this.
#33
so how does this vent hose work? If it's supposed to vent the hydrogen gas given off how does the gas go down the tube. Since the gas is lighter than air it seems like the gas would escape upwards if there wasn't a perfect seal around whatever it is that attaches to the top of the battery.
#34
#35
Correct answers, NOT guesstimates, that's why many of us including myself have come here for truthful REAL answers and not heresay. Too bad the more I see lately is heresay and he did it so I did it and so on and so on and so on so then it must be correct??. That's just bandwagon jumping without FACTS on whether it's right or not right to do. Anyway ... and no biggie on my end. I'm not upset nor sweatin' the small stuff. Let's try to be amiable to agree or disagree.
#36
I just replaced the battery in my 09 Z06, 8 years old and always on a battery tender, Battery Tender Plus model, and vent tube in place. The other day I drove the car just to get the fluids circulated. When I got home and parked it, and about an hour later I tried to start the car one touch of the starter button and bang, the battery blew out both sides.
I replaced it with a 90 EXT from O'Reilly Auto Parts. The battery has the position for the vent tube on both ends of the battery and like the original, a plug is furnished for the side not in use. However, for some additional safety, I am going to add a second vent tube.
#38
I was checking the connections for the battery on my 08z and noticed a hose that was flopping around coming from the wheel well? It has an end on it that makes it appear it should be connected somewhere but I didn't find any place that looked like it would fit. Anyone know what this hose is for and where it plugs into?
