C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Vansteel bushing install
Old 12-31-2016, 04:51 PM
Whis9
Whis9's Avatar
Default Vansteel bushing install
I will try to document the process as best as possible for anyone interested.
Probably be over the next few weeks due to work
1st day did some cleaning
Bad_AX (12-31-2016)
Old 12-31-2016, 06:01 PM
zblackz06
zblackz06's Avatar
Are these stock bushings that you are installing?
Old 12-31-2016, 06:21 PM
meanjoe
Support Corvetteforum!
meanjoe's Avatar
https://www.vansteel.com/index.cfm?f...&SubGroup=1995
Nice stuff.
Brandon619
Brandon619's Avatar
See link.
https://www.vansteel.com/index.cfm?f...oups&navid=128
Old 12-31-2016, 06:27 PM
zblackz06
zblackz06's Avatar
Please let us know how they work out for you, I am planning this mod in the future.
Old 12-31-2016, 08:40 PM
Whis9
Whis9's Avatar
Old 01-01-2017, 02:38 AM
Z2Z
Z2Z's Avatar
Im really interested in a review too. I'd love to have sharper steering. My cousin's S2000 makes me jealous every time I drive it.
Old 01-01-2017, 07:16 AM
sccaGT1racer
sccaGT1racer's Avatar
The van steel kit is a very easy install and is well designed. I did my complete install in 5 hours. The car will have much improved steering response but will be noticeably harsher on rough roads. The slotted uppers are a nice added feature for caster adjustment.
When installing make sure there is no bind on the metal sleeves to the delrin.
Old 01-01-2017, 09:58 AM
edmundu
edmundu's Avatar
Originally Posted by Whis9
1st day did some cleaning...
What/how did you get them that clean?
Old 01-01-2017, 11:09 AM
Mordeth
Mordeth's Avatar
Received 1,678 Likes on 878 Posts
2018 C6 of Year Finalist
St. Jude Donor '10, '17
I am in for this. According to their website, you can send the control arms in for chemical cleaning.
Are people doing the entire kit?
Old 01-01-2017, 11:25 AM
Whis9
Whis9's Avatar
Front and rear, rubber bushing move so much, I was shocked
Old fashion elbow grease
Scrubbed them down in tank and very mild wire wheel
Old 01-01-2017, 01:10 PM
zblackz06
zblackz06's Avatar
I spoke to Ride tech a few months ago at Carlisle and the first suspension mod the suggested I make was their Delray bushings due to the fact the factory rubber bushings "deflect or vibrate" especially while cornering.
Old 01-01-2017, 06:02 PM
rabrooks
rabrooks's Avatar
Brass wire wheel in a drill works well and is quick. If youre real picky about how the undercarriage looks, you can clear coat the parts after the cleaning. It'll get dirty but easy to clean and no more oxidation
Old 01-03-2017, 07:37 PM
Whis9
Whis9's Avatar
Old 01-03-2017, 09:51 PM
Bad_AX
Bad_AX's Avatar
No need for a blow torch or heavy grunt work! Nothing like a Made In America Wilton vice to show the rubber bushings who's boss! The guy at Borg Motorsports needs to have a look at this approach. He's doing it the hard way.
I am curious about the Loctite?
Rock on!
Old 01-04-2017, 05:49 AM
Whis9
Whis9's Avatar
Loctite is for loose fitting bushings
tolerances for these arms are fairly large
all the bushings are CNC machined to a tight tolerance
Old 01-05-2017, 03:25 PM
MTPZ06
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
Pretty cool! In for reviews/impressions after install.
Old 01-05-2017, 07:12 PM
Whis9
Whis9's Avatar
Will do
Winter here so will 3-4 months
Old 01-05-2017, 07:21 PM
MTPZ06
MTPZ06's Avatar
Will do
Yeah, I know what you mean...it dipped down to 68* here late last night. People had to break out their hoodies.
To Vansteel bushing install
Quick Reply: [Z06] Vansteel bushing install
