[Z06] Walbro 450 Pump users come in!
About to order all of the components for my E85 flex-fuel system (sensor, wiring, plumbing etc) and would also like to run the walbro 450 as the stock pump is not designed for e85 use. Have done a bunch of reading on installing the 450 pump in the stock hat, and it seems some have to do some cutting. Also some have mentioned that the 450 pump does not have a "jet valve" or something like that and therefore can lead to a lack of prime and hard starts until fuel pressure builds. Just looking for insight on these two issues from people who have installed them. Any other useful tips, tricks or helpful threads are appreciated.
Thanks!
Thanks!
From Racetronix....
The fuel pump also supplies fuel to the venturi pump located on the bottom of the left fuel sender assembly. The function of the venturi pump is to fill the fuel sender assembly reservoir.
From my understanding, it uses a siphon effect to make sure the bucket always stays full, which means the pump shouldnt ever suck air. If you dont ever run the car low on gas, this isnt an issue as the bucket will stay full anyways.
Not worth the risk for me. $100 fuel pump designed for E85 vs stock pump not designed for E85. Would hate to have the pump fail creating a lean condition and blowing a $15k motor.
My fuel rails have a port for a pressure gauge. My hope is that I'd notice a low pressure condition and it would be easy to verify with a peek under the hood.
I do not have your same platform but I do run the Walbro 450 pump on my E85 return fuel system twin turbo car. I have monitored my fuel pressure guage and wide band AFR guage and never lean out.
